DIY Metalcloak 3.5" Game Changer Lift Install and Review
Toniagp
NPR, Florida
2020 JLU Sport S 3.0 EcoDiesel
Hey! No worries! Always happy to answer questions, if I can. The new suspension I got is a custom long-arm setup from the shop that sponsored me, Offroad Addiction, Inc in Edmond, Oklahoma. They designed and fabricated their own control arms and brackets, and then we used Falcon 3.3 series adjustable shocks, Teraflex springs and bumpstops, and SteerSmarts Yeti steering components. It rides better than the MC lift I had primarily due to the Falcon 3.3s (which you could add to the MC lift). And my setup is more capable off-road because the MC lift was a mid-arm lift, and a long-arm will always be inherently more capable off-road.
So, I still highly recommend the MC 3.5" GC lift in most cases, because my setup is highly customized (which requires more maintenance than the MC lift), and my setup isn't easily reproducible, unless you live near Edmond, OK. The MC lift is still, in my opinion, the best "off-the-shelf" lift on the market.
Hope that helps!
Thank you so much.. Answers all my questions! Falcon 3.3's anyone you recommend to contact for those? And I just tell them what lift kit I'm ordering and they should know the length and all that i should need?
ALEX-4LO
Alex
No where
2018 JLUR & 2020 JLUR - Project JL's
After 10k miles on my MC lift. The control arms are great. The true dual rate coils are super flexy. The rocksport shocks are trash. Very stiff and uncomfortable. Will be going to King/Fox shocks/setup in the next month or so.
ALEX-4LO
Alex
No where
Might be doing EVO MFG plush springs w/ King Shocks. Depending on the deals out there. But MC kit is a great starter kit for sure.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Google Data Center Maintenance Program Manager
Call Offroad Addiction in Edmond, OK - (405) 752-7467 - https://www.offroadaddiction.net/ and tell them Swampcat sent you! They'll get you setup.
Memcdowe
North Alabama
2020 JLU Rubicon 2.0
Thanks! I started at the suggested 19.75 and 24. I haven't re-checked caster since a couple of drives to see if anything settled in so I'll verify I'm still at 7 degrees.
It definitely doesn't drive great so it needs something, but I've hit offset potholes that used to give my SuperDuty DW and nothing. IOW it does not exhibit any predilection toward DW so I'm likely not lacking caster (edit: even with 38's and 1.5" wheel spacers, no DW)
Hey did you ever figure out why yours wasn’t driving great?
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
If you're willing to spend $1500 on falcon 3.3 shocks, I would much rather have some Fox remote reservoirs custom valved by Accutune or some Kings.
Agree fully with this, and Fox will ride much nicer.
word302
Oregon
JLU
Hope that helps!
Lol. It doesn't ride better because of the Falcon shocks, which are junk. It rides better because it's a long arm suspension.
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
The falcon 3.3s would not be a pairing I would suggest at all. Will be very harsh. If you’re at that price point for shocks, I would consider some custom valved ones. They will be tailored to suit you’re particular set up.
Brett
Rosco1983
Ross
Hutchinson ks
2019 Rubicon
I think I read somewhere that the metalcloak 3.5in lift is more like a 4in lift. Does anybody else find this to be ture?
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
Almost all lift springs will give more than advertised lift. They are built with the assumption you will add weight to your Jeep.
Jimmy_jak
Central Florida
2019 JLU Sport S
my 2.5 from MC is definitely more than advertised. Which I love!
Memcdowe
North Alabama
Thanks!!
The only issue I ran into driveshaft-wise was during the install. I did the lift after having installed a full set of Rock Hard 4x4 skid plates. Short version, the skids prevented the driveshaft and front axle from drooping enough to get the driver's side spring out easily, so I had to use a spring compressor. Not a big deal. As for off-road, I haven't seen any issues with the driveshaft.
I'm working on editing the video now. This is my first DIY video, so it's a learning process, but it should be done soon. It'll go up on my YouTube channel when it's done. I'll post a link here though.
I'll look for a good before/after angle to post and get it in here later today.
Hey did you ever post the DIY video to YouTube?
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Hey! Sorry, no I haven't even edited it together, haha. I can share the raw footage with you, if you like. PM me.
