DIY Immobilizer
c0wb0y
Richard
Idaho
2022 Jeep Wrangler Sport
Hello. I am new to this forum and this is my first post. My name is Richard. I have a 2022 Wrangler Sport 2 door which I purchased new 18 months ago. Thank you for allowing me to participate.
Here is my frustration: The FOB that comes with this Jeep is huge (not news to you all - but I was shocked). My sole form of transportation for the last 15 years has been motorcycles with codes or small FOBs and moving into four-wheel transportation with a brick that barely fits into my pocket and makes my pants sag like they are filled with sand is just more than I had bargained for. It did not take me long to come to a decision. I had a copy of the metal key made for my keychain so I can lock and unlock my door and I keep the FOB in my Jeep. Let us not dwell on that point or the stupidity of it - I am doing it and it is non-negotiable. However, to feel better about it, I want to install a home-made on/off switch that activates the Jeep's Start/Stop button. I have a plan and I would like some comments from you experts on whether I might be hurting something or causing some problems with the electronics. Here is my Plan "A":
Fuse F10 powers the Jeep's Start/Stop button. If I pull the F10 fuse, the Start/Stop button does not light and the car cannot be started. If I put a fuse tap in place of the F10 fuse and a switch on that tap to control the power through that fused circuit, then I can use that switch to simulate pulling and replacing the fuse to allow the Jeep to start or not. The only problem I can think of is that the constant on/off of the circuit may cause a problem to the PCM or ECM or ECU or whatever they are calling it this week. Here is a simple schematic of my plan. I would enjoy hearing whether anyone believes this Plan "A" is a good or bad idea.
As an enhancement of plan "A", I would like to not have to remember to turn my on/off switch to the "off" position every time I leave the car and would prefer to have that be automatic every time I push the Jeep Start/Stop button to "Stop". This is my Plan "B" and is easily accomplished by adding a latching relay to the system which will be powered by the ignition available in the F45 fuse and substituting my on/off switch with a momentary switch (thus, when I press the momentary switch to simulate replacing the F10 fuse, and hold it while also pressing the Start button, this energizes the ignition power which also then powers the relay from the "normally open" position to the closed position and completes the F10 fused circuit until I press the Stop button to cut the ignition power). Again, here is that schematic. And, again, I would enjoy hearing whether anyone believes this Plan "B" is a good or bad idea.
Thanks for your help!
Jeep Wrangler JL DIY Immobilizer Plan A
Jeep Wrangler JL DIY Immobilizer Plan B
Reinen
2021 Jeep Wrangler JL Rubicon
You're making this more complicated than it needs to be. Just buy a threedom keyfob that makes it smaller and removes the key from the fob.
https://mythreedom.com/pages/fobs
Just be aware that without the key if the fob is damaged or the battery dies you could be locked out. I've had to revert to the key and press the start button with the key fob twice.
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
That's why you buy threedoms little key chain attachment piece that holds the key, it's like $5 or something. Plus OP mentioned he already carries the key he had made.
c0wb0y
c0wb0y
Richard
Idaho
Thank you for your words of wisdom! I was not aware of the Threedom keyfob. If I had not already had a metal key made, this would be a better solution than Jeep's brick. But, even so, I may not have liked the smaller, but still bigger-than-a-key Threedom keyfob. As it is now, I have to carry only the metal key and I enjoy the light weight in my pocket. If my Plan A or B works, then it, really, is a better solution than the Threedom keyfob (as nice as it is).
I am still hoping that someone with some legitimate experience with the electronics of the Jeep can answer my concerns about my change to the electronics.
GrumpyOldVet
Missouri
'24 JLURX, '21 Chevy Tahoe RST, '21 HD FLTRK
You could "Just Do IT(TM)" and let us know how it works :D I really like your idea with the momentary switch and the relay. Logically the whole idea makes sense. Hopefully someone can chime in as to whether or not that circuit does more than just act as a momentary switch itself.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Exactly what I did. Threedom M+ FOB w/'Jeep' key head. So much better than the OEM FOB.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
What you want is the small key with RFID pocket. Then just push the button with key to start.
https://mythreedom.com/products/key_holder
To answer your question, I think your hidden switch, momentary or not, will not affect the PCM.
c0wb0y
c0wb0y
Richard
Idaho
In response to "Just do it" - well - I have already done it (Plan B). And it works great. But, I am still looking for an expert's (or semi-expert's) seal of approval that I am not messing something up.
c0wb0y
c0wb0y
Richard
Idaho
Or. Remove the battery from your fob.
that way you can’t start unless the RFID chip is touching the start button.
And hide the fob in the car. You could put it inside a beanie baby or inside a duck.
When you need to start. grab the fob duck and put it close enough to the button to start the car.
Not a bad idea. My wife likes the idea of putting the RFID inside a stuffed animal.
I appreciate all of the advice. Thanks, everyone!
