jlewissystem
Thanks! Did we just become best friends? Haha. I had remodeled the garage a little over a year ago for my other car, so had to get the matching Jeep
Now i want to go do Karate in your garage!
I need some advice relatively quickly... I was looking at hardtop hoists and was leaning towards the Racor hoist with the Topsy kit. I have a low ceiling 8' max and looking at adding a maximus-3 roof rack. After a bit of forum searching and e-mailing Topsy I figured out I could make this work and planned out how to do it.I was keeping an eye on prices for a couple of months and youāre right - they only went up. So I bit the bullet. Very happy that I did. It makes the entire process a breeze!
Interested to see what Topsy comes out with.
Yikes! If this is the solution youāve settled on, then yes Iād buy it. It was $180 when I started looking and $230+ when I ended up purchasing. Just looked on Amazon and the cheapest is now $399.I need some advice relatively quickly... I was looking at hardtop hoists and was leaning towards the Racor hoist with the Topsy kit. I have a low ceiling 8' max and looking at adding a maximus-3 roof rack. After a bit of forum searching and e-mailing Topsy I figured out I could make this work and planned out how to do it.
Now before I could move on this I needed to clear out an old 1880's carriage barn and stabilize the floor etc...so I did not purchase it right away... Today I'm in the process of installing lighting and decided to check on the dimensions to make sure I left enough room for the hoist and It's now listed on Amazon for $460!!! On top of this the Topsy JLU kit is sold out...
I checked their website and it doesn't mention that its been discontinued but I found a post here that mentioned it was being discontinued...
So at this point I started looking every where for it and found it at several places for over $500... However I did find 2 postings on Ebay 4 total units at $259 and $279 respectively...
Should I jump on this...
I bought it at $279... More then I expected but okay. There were two for sale now the last one is listed at $555!Yikes! If this is the solution youāve settled on, then yes Iād buy it. It was $180 when I started looking and $230+ when I ended up purchasing. Just looked on Amazon and the cheapest is now $399.
Thanks for this.I like it. Two things though.
1. Wood will be sufficient, as you've got it drawn, if you're only using it for the hardtop and freedom panels. At most, I'd add a cross brace on the top component, but no need to upgrade to aluminum.
2. You're not going to get enough travel to lift the top with the hoist located where it is. That's assuming you're using the supplied cable and hook.
The yellow lines show your travel limit, which is very small. Again this is assuming you connect to the supplied line/hook on the hoist. This is limited because the hook stops at the hoist, and won't be able to go past the 2 rollers. Therefore the distance between the hoist and rollers is going to be your maximum travel.
You can eliminate that restriction by spooling your own lines to the hoist, or by relocating the hoist location. Either using a remote location, or by moving the hoist to the opposite side of the frame. By moving to the opposite side you can connect the hook near the rollers (with the lift in the "down" position). Another roller (or set of them) would be needed to reverse the direction of all the lines toward the hoist. However doing this would give you a maximum travel of whatever the width of your top frame is.
Without pulling up my drafting software, here's a crude example of the revision.
Again, this is all assuming you're using the supplied cable and hook. If you're spooling your own line, this is all moot.
Supply and demand my friend! They need a competitor to knock them down a bit.Omg the prices for that racor lift are all over the place. Checked amazon last night and it was $500, today they are $400. What the heck is going on with this company?
Doubt its the company .Omg the prices for that racor lift are all over the place. Checked amazon last night and it was $500, today they are $400. What the heck is going on with this company?
