chevymitchell
- Shawn
- Feb 18, 2018
- K-ville, NC
- 2019 JLUR (Pain Train), 2022 2500 AT4
- Occupation
- Avi Engineer
That sounds very wrong. Adding in .040” is locking up the diff? Locking up the diff is likely backlash. Can you share a video explaining what’s happening or showing what’s being done? Triple check that the races are pounded in all the way and the pinion bearing is on all the way. Also, where are you applying the shims? Thanks man.Ok, adding back in pinion shim was causing the carrier to contact the pinion head and freeze up the diff. That took a while to figure out. Time to pound out the pinion race and try reducing the shim to see if I can get an acceptable pattern that clears the carrier.
