DIY Door Installation Pin Guides
Jebiruph
Jerry
Iowa
2018 JLU, 2019 KL, 2020 JT
With all the door removal/installation taking place, I thought I'd share these door pin guides I made with 3/8 OD, 3/16 ID vacuum tube cut to 1 1/4" length. They make it much easier to install the doors. I push them on just far enough for them to stay on, then pull them off after the door is installed.
Chocolate Thunder
Jeremy
I’ve only removed the doors a few times, but how does this help make it easier?
RichD
Rich
Boston
2018 Sport S
I imagine that it let's you line up the pins to the hole without damaging the hinge or the threads. Great idea Jerry!
Jebiruph
Jebiruph
Jerry
Iowa
This is correct. There's no metal to metal contact when trying to align the pins to the hinges.
Jebiruph
Jebiruph
Jerry
Iowa
And now that I think about, I should have made a slanted cut to make it easier to "spear" the guide into the hinge.
Chocolate Thunder
Jeremy
Oh! Now I see. I didn’t have a problem because the doors are pretty light, but I can see how that might be an issue for some people especially if you’re doing it in the dark or it’s windy etc.
OffroadTreks
Boise, Idaho
2018 Jeep JLU 2.0TE
I didn't realize people had difficulty aligning two pins.
Quake LED
