Jeep007
- Andrew
- Feb 23, 2018
- Long Island, NY
- JLUR
I decided to install 3m ppf on the door hinges today and took some pictures of how I completed it. This isn’t a very difficult task just requires a lot of time and patience.
First I order a small roll of film from amazon. https://www.amazon.com/gp/aw/d/B01LWPKZCF?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
When it arrived I taped it to a flat surface over night to get out any wrinkles.
Next using blue painters tape I created templates of the 3 sections of the door hinge I was covering. This will involve some trial and error when cutting the tape to fit.
I then layed the template over the back of the film and used a sharp utility knife to cut out. Need 8 total of each section.
After cleaning the surface, peel the back of the film off and apply the film in a rolling motion from one side to the other (prevents bubbles). Then firmly press down/rub the film to secure it.
You may mess up a few times in the beggining but there is more than enough film to use if you do. I also placed a line of film on the edge of the back doors too.
That’s really all there is to it. Hope this helps if you plan to do it.
