bllprk
- Brian
- Aug 6, 2021
- Kalamazoo, MI
- 2008 WK CRD
Good evening,
So, I have installed the Centerforce clutch.
I am having trouble with the hydraulics. The clutch engages when the pedal is only 1/2” off the floor.
When I install the slave, into the bell housing, i don’t have to compress the slave much. When I measure, the distance from the fork to the housing, is just less than the length of the extended slave piston.
Really feels like I did something wrong.
I have used every bleeding technique I can find including using the vacuum bleeder.
Any advice? Thank you!!!
