DIY 4-Tire Tire Inflator / Deflator
Unkle Fester
Kendall
Abandoned Graveyard
2020 JLU Rubicon Recon
I’m really glad I found this thread. Thanks all....
szobell
szobell
2022 JLUR
You will love it.
One other thing now with some time with mine. I want a "liquid filled" pressure gauge as I get a crazy vibration with my gauge from my compressor. Everything else I absolutely love.
I have yet to find the gauge that I want - once I do - I will post it here.
Medsker
Jon
Herriman, Utah
2019 JLUR
No Worries. I hope it works for you.
TheRealChad
Chad
Los Angeles
2021 Rubi 4xe
There's no place to mount it on my JL. I'm just going to hook it to my battery under the hood when I use it.
@jerseymike i bet the tank is awesome. To big for my needs.
@szobell
This is the valve.
DERNORD Brass Mini Ball Valve NPT Thread,Chrome Plated (1/4" Female&Male) (Pack of 1)
https://www.amazon.com/dp/B07KMR9H9D/ref=cm_sw_r_cp_api_i_a4tOCb0HWS697
This is the manifold
Interstate Pneumatics FPM44S Aluminum Rectangle Pencil Manifold 4 Way Outlet 1/4 Inch NPT Female
https://www.amazon.com/dp/B002RRRIOK/ref=cm_sw_r_cp_api_i_F5tOCb6PP9ZKT
This is the couplers
ColorFit by Milton Coupler & Plug Kit - (M-Style, Red) - 1/4" NPT, (14-Piece)
https://www.amazon.com/dp/B073R7GG98/ref=cm_sw_r_cp_api_i_r6tOCb63YHBAS
I also have added 3 release valves to let the air out.
Which release valves did you use? thanks!!!!
JoeValkIS
Arnold, MO
2018 Wrangler Rubicon, 2019 Can Am Spyder F3T
I redid mine to this configuration...I did have coiled hoses everywhere but it was a pain to get everything strung out. Flat hose is the way to go for the main lines. Almost all of it came from Harbor Freight....including the bag I have it stored in.
Jeep Wrangler JL DIY 4-Tire Tire Inflator / Deflator 1635537066595
Jeep Wrangler JL DIY 4-Tire Tire Inflator / Deflator 1635537083029
Jeep Wrangler JL DIY 4-Tire Tire Inflator / Deflator 1635537098103
Jeep Wrangler JL DIY 4-Tire Tire Inflator / Deflator 1635537113983
And I wired a 7-pin plug to my Viair 88P Compressor so it will connect to my trailer light socket.
Jeep Wrangler JL DIY 4-Tire Tire Inflator / Deflator 1635537331820
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
Nothing fancy, but it works and its fast with my ARB compressor.
Jeep Wrangler JL DIY 4-Tire Tire Inflator / Deflator 9D563841-35B3-4B0B-893B-B59A736AF571
Jeep Wrangler JL DIY 4-Tire Tire Inflator / Deflator DE499F63-0EA6-47FF-8B87-052927CE5BAD
