Levin_tom
Are you guys using any relocation brackets to install the Falcon Nexus 2.2 Steering Stabilizer? Or are you using stock steering components?
I didn't use any relocation brackets.Are you guys using any relocation brackets to install the Falcon Nexus 2.2 Steering Stabilizer? Or are you using stock steering components?
Well, I didn't initially and planned to relocate later. Then I landed the SS and tie rod on a rock... Now I have a new SS with Metalcloak relocation bracket.Are you guys using any relocation brackets to install the Falcon Nexus 2.2 Steering Stabilizer? Or are you using stock steering components?
I just searched since and found this thread. I have the same issue. My question is if it impacts the actual workings of the SS if the knob is backwards? Can I just assume soft is the firm setting and carry on or does it need to be flipped to work correctly?I did the exact same thing when installing mine. There is nothing wrong with the SS, something went wrong with the install. It's been quite a long time since I installed mine, but I remember calling Teraflex and they told me what to do to fix it. It was super simple, I just can't remember exactly what I did. I'll crawl under tonight and see if I can jog any memories.
Edit: Vague memories are popping up. I think you have to turn the entire rod with the switch 180 degrees. I remember unbolting it and turning the rod by hand using the bolt at the other end from the switch for leverage.
You’re looking at the switch backwards, but it still works properly.I just searched since and found this thread. I have the same issue. My question is if it impacts the actual workings of the SS if the knob is backwards? Can I just assume soft is the firm setting and carry on or does it need to be flipped to work correctly?
Thanks. Then I'll just get it flipped the next time I get some work done.You’re looking at the switch backwards, but it still works properly.
Regardless of the knob orientation, either facing forwards or rearwards, the stabilizer will function the same. Either unbolting the red knob and spinning it 180 or unbolting the rod end and spinning it 180 will correct the issue.I just searched since and found this thread. I have the same issue. My question is if it impacts the actual workings of the SS if the knob is backwards? Can I just assume soft is the firm setting and carry on or does it need to be flipped to work correctly?
