Grimm_E
If you look at the well there are no pre drilled holes in it. if you have put it in incorrectly the hole you make is in the wrong place. when the bolt is removed and the well is repeated a new hole will need to be drilled, leaving an extraneous hole from the improper install.So the original liner isn't acceptable if they take it out and then install it correctly?
