Diode Dynamics Video: How to Install 2018 Jeep JL Wrangler Switchback Turn Signal LEDs
mwilk012
2018 Ocean Blue JLU Rubicon
Service
XP80s do work. That's actually my Sahara on DD website with the 80s.
Did you send the video to them or did you take it in to be worked on and photographed? I have been talking to DD over the past month or so and they haven't been able to get another Sahara or Rubicon to test on.
Cledus601
Clint
2018 JLU Sahara
I sent the pictures to them.
Ralph2018JL
I used some double sided gorilla on the bottoms and stuck it to that pinch weld up there above the braket. It is tight but its in there.
Did you have to remove the inner fender to gain that much access? Thanks!
Cledus601
Clint
2018 JLU Sahara
I didnt completely remove the inner fender. I took the forward half loose and folded it down. It is quite pliable.
Ralph2018JL
Thanks, before I realized I could do the same, I was under the wrong assumption that the rivets around the edge of the fender flare held the liner in.
Cledus601
Clint
2018 JLU Sahara
There are a couple bolts and washers and then the little push clip button deals if I remember correctly
salvadorsantana
SS
Miami, FL
2018 JL, 2017 JK
So I bought this kit and Im getting hyperflashing on my dash board but not outside. Is this normal? I have an Sport S.
mwilk012
Service
Yes I did. I bought their $70 kit that includes the 7443 pair of bulbs and resistors. Wired resistors to white/green and black cables. Just got it on video (sorry about vertical recording) :whew:
Nope, not normal. May need to reset things.
Cledus601
Clint
2018 JLU Sahara
Can you get to the resistor? Verify you have a good connection. Touch it while the blinker is on, they get pretty hot fairly quick. My first guess would be that there isn't a solid connection.
salvadorsantana
SS
Miami, FL
2018 JL, 2017 JK
PROBLEM SOLVED...
I went back onto Diode Dynamics Youtube video and watch it over and over to see if I had missed something.
Then starting to look on Youtube for other "resistors installs" and one thing that I noticed was that everyone was using the pliers to secure the quick splice directly onto the blade and not on top of the "cap" of the quick splice as the guy on the Diode Dynamic showed on their video.
So I went back to try squeezing one more time the quick splice directly onto the blade firmly and BOOM now the hyperflashing on the dashboard is gone. Flashing rate is normal inside and outside.
RIGHT WAY TO SQUEEZE QUICK SPLICE
WRONG WAY TO SQUEEZE QUICK SPLICE
