WranglerMan
- Will
- May 8, 2018
- Katy Texas
- 2018 Wrangler JLU Sahara
- Occupation
- Gas Pipeliner
- Vehicle Showcase
- 1
Ok guys this goes out to anybody that has swapped from a non LED bulb to an LED bulb for the DRL’s in a Sahara as apparently it’s different than the Wrangler and Sport as it cant run the switchbacks as the Sahara uses two bulbs.
Apparently there is a possible issue running the DD 7443 XP80 in a Sahara since it requires two levels of brightness ( one for idle and one for driving ) so with that said who has had success swapping to an LED bulb and not a factory LED setup.
I called DD and a phone rep advised he had heard of a ponrential issue in the XP80 and suggested either the HP11 or 48 versus the XP80.
So who out there has swapped out there DRLS and what have you used with success
