Diode Dynamics: 2018+ JL Wrangler Fog Light LED Bulb Replacements! Install Video! USA Made SLF!
  1. Diode Dynamics
    Diode Dynamics Well-Known Member
    Summit Sponsor (Level 3)
    Vehicle(s):
    2015 F-150 / 2015 Mustang / 2016 Camaro
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
    Jeep JL Wrangler Fog Light LED Bulbs
    [​IMG]
    Diode Dynamics carries LED bulbs for replacement of your Jeep JL Wrangler's fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your JL Wrangler's fog lights a nice bright white that closely matches factory-equipped HID or LED lighting!
    Just simple plug and play, replace the bulb and you are good to go!
    Diode Dynamics offers the brightest, highest-quality bulbs on the market. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
    Brightness:
    Diode Dynamics offers several brightness options so you can choose what fits your Wrangler's output needs best. These options are listed by the design and the lumen output of each bulb, compared to the factory halogen bulb.
    HP48: 265 lumens. Slightly lower brightness than factory.
    XP80: 510 lumens. Similar brightness to factory.
    SLF: 850 lumens. Street Legal Output. Much brighter than factory. These are bright! USA Made!
    *SLF is available in 3000K Yellow / 5,700K Cool White color temperatures
    Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
    These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
    [​IMG]
    Bulb Design
    HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
    XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
    These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
    Included in your order is TWO BULBS (to fit your Jeep JL Wrangler Sport Model).
    Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
    [​IMG]
    Diode Dynamics: Fog Light LEDs for 2018+ Jeep JL Wrangler
    Click below for more info or to order:
    If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks for looking!
    Nick C.
    [​IMG]
    Cledus601 likes this.
  2. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
    Why Do Yellow LEDs Look Green? | Yellow LED Fog Lights from Diode Dynamics
    Command Line RC likes this.
  3. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
  4. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
    Don't forget to send us a PM for the free-shipping code!
    (U.S. addresses only)
    Thanks!
    Nick C.
  5. XtremePunesher
    XtremePunesher Well-Known Member
    Vehicle(s):
    2018 XTREME JLU
    Apr 16, 2018
    New York City
    99
    Liked:
    63
    Occupation:
    Architect/Builder
    Hi what's the code for shipping
    Diode Dynamics likes this.
  6. MikeinMD
    MikeinMD Well-Known Member
    First Name:
    Vehicle(s):
    1968 Mustang Convertible, 2003 Z71 Suburban, 2018 JLU Sahara
    Jan 22, 2018
    Maryland
    304
    Liked:
    605
    PM = Private Message
  7. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
    Thank you for sending us a PM!
    Looking forward to seeing pictures with our product installed on your Wrangler!
    We appreciate your support,
    Nick C.
  8. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
    Questions about lighting upgrades for your 2018 Wrangler? Give our team a call: (314) 205-3033
    We are happy to answer any questions you may have!
    Nick C.
  9. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
    Diode Dynamics' SLF LED Fog lights maintain an OEM output pattern thanks to their unique optical design! This results in no additional glare for other drivers on the road.
  10. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
    Engineering | The Diode Difference | Diode Dynamics
  11. Man-of-methods
    Man-of-methods Well-Known Member
    First Name:
    Paul
    Vehicle(s):
    2018 Jeep Wrangler JLUR (His) 2018 Jeep Wrangler JLUS (Hers)
    Dec 16, 2017
    502
    Liked:
    595
    Garage Profiles:
    Do you guys have a 912 bulb for the domes that are brighter than stock? I haven't taken the dome apart to see the bulb size (round, square, etc)
    Thanks
  12. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
    Hello Paul,
    We have a variety of replacement options for that size, but to our knowledge, the JL does not use any incandescent bulbs for the interior. Would you mind sending us an email with a bit more information? [email protected]
    Thank you!
    Nick C.
  13. Valdi2502
    Valdi2502 New Member
    First Name:
    Carlos
    Vehicle(s):
    Jeep wrangler 2018 jl
    Jul 29, 2018
    Miami
    Liked:
    Anybody know what is the bulbs size in jeep wrangler 2018 jl?
  14. Valdi2502
    First Name:
    Carlos
    Vehicle(s):
    Jul 29, 2018
    Miami
    Liked:
    Jeep wrangler 2018 jl fog lights bulb size
  15. OP
    Diode Dynamics
    Vehicle(s):
    Feb 28, 2017
    St. Louis, Missouri
    372
    Liked:
    111
Loading...
Share This Page
