Dims of MPS Overhead Molle Panel
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Does anyone have the MPS Overhead Molle Panel? If so, can you measure the dimensions? Width and Length from back side of the windshield to the front side of the roll bar?
https://www.molle-platform-solution...-wrangler-front-overhead-molle-panel-hard-top
I'm considering switch panel / wiring solutions ahead of taking delivery of my JLUR 3.0. One option I'm considering and leaning to at the moment is an overhead switch panel with Carling SPST and DPDT rocker switches. I had these in a previous overland vehicle and had the DPDT switches configured so the accessory would be on in one position or remote triggered in the other. Driving lights triggered by high beans, reverse lights triggered with reverse, rock lights triggered with doors opening. You get the idea. Trying to decide if I have the enough area overhead to make this work.
conFUcius
Stephen
North Carolina
2020 Sting-Gray JLU Rubicon 3.6 V6
Medical Affairs
Did you end up buying one? Curious how difficult the install was with drilling some mounting holes.
GtX
Illinois
2020 JLUR 3.0D
I did. I ditched the self tap screws and installed some rivnuts.
conFUcius
Stephen
North Carolina
Medical Affairs
Jeep Wrangler JL Dims of MPS Overhead Molle Panel 20210710_151455
Both front/back need hardware, right? I presume there’s nothing from an OEM standpoint you use.
GtX
Illinois
2020 JLUR 3.0D
I only did the front.
AMT
Adam
Pensacola, FL
2021 JLUR 2.0T
I just installed one this weekend. Did the same thing for hardware: 4 rivnuts. Also put in some rubber washer under the rear flange; had about a 3/4" gap above the sound bar where it was supposed to mount. Not sure if this is similar to what you are wanting, but this dude did a nice job with the aux switches and the panel together:
proptied
WI
22 JLR Snazz
I had the same problem with a gap like this: front and rear. I found if you either pre-bend it or, like I did, give a little downwards tug on it while it's up there it'll flatten out. Not sure if it was intentionally bent like that or not, but it feels more solid now that it's flush.
