Dimension of Rubicon 392 with Xtreme Recon package?
Hearhear
Lexus, 392 XR Wrangler
Hello, I wanted to find out accurate dimensions of a Wrangler Rubicon 392 with Extreme Recon package- length, width and height. I really need to make sure this will fit in my average sized suburban garage. Not a lot of room. Thanks
Ridgway Jeeper
Frank
Ridgway, CO
2021 JLR
Real Estate Agent
Pretty tough to get "accurate" measurements of something not built yet... You are probably only looking at a 2" height gain and maybe 2 " in width, the length wont change. Should still fit in most garages easily.
SLORubi
Stephen
Grand Rapids, MI
2018 JLUR; 2019 A4 S-line
I’m curious about the weight. Jeep lists the 392 at 6100 lbs, the XR has to add maybe another 200?
Bo Ran
Randy
2021 Rubicon 392
I own a 2021 392 with XR package. GVW is 6,100 lbs according to door sticker inside driver side.
FYI: 6,100 lbs. qualifies vehicle for 100% write-off deductibility in 1st year if purchased by business for business use.
nypharm
Danny
NY
2021 Toyota 4Runner TRD PRO
Anyone know the height of 392 xr, wonder if it can fit in my work garage. My 4runner trd pro, has 2 inches to clear with that massive roof rack.
stumblinhorse
Hardtop 392 on 35s at 30 psi is no more than 75”. XR and non XR are the same height.
Hardtop is curved or arch shaped, so 75” is the peak in the middle in the back.
nypharm
Danny
NY
You ride your 392 on 30psi? When I had my wrangler, never went below 32-33. Thanks for answering my question.
Diode Dynamics
