Differential Oil
Obus
Donald
NY
2021 JL Wrangler
My 2021 Wrangler Sport JL manual says use SAE75W85 oil in the front axle and then use SAE75W140 on the rear (M200 Sales Code DRZ). But if I have a rear axle (M220 Sales Code DRE/DRF) use SAE75W85? How do I know what I have?
Pape
Quebec
JLU Sahara
Little off topic here but how do you find the sale code ?
Kracka
Christopher
Oak Point, TX
C8 Corvette, 19 KL Trailhawk Elite, 23 JL Rubicon
Count me as the odd man out: I stick to OEM recommended spec and use Redline 75W-85 GL-5 gear oil front & rear in our Rubicon and Amsoil SG 75W-85 GL-5 gear oil front & rear in our Grand Cherokee.
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Just use 75/140 for both. Makes buuing gear oil easier and is what Dana (not Jeep) reccomends for the axles. You might see a 1% drop in fuel ecoomy, but I'll take the manufacturers advice.
I will add, when I did my first gear oil change at 40k the origional fluid was black and a bit stinky. Just chsnged again after 80k miles and it looked brand new
Heimkehr
Pennsylvania
2021 JLU 2.0T
+10.
After my selling dealer refused to perform a transmission fluid and filter change, despite my having a page from ZF that recommends that service at ~60K miles, I decided to investigate what the actual designer/manufacturer of other drivetrain components recommend for periodic maintenance.
As soon as I found data from Dana that recommended, or at least allowed, the use of 75W-140 in both of my axles, and in contravention of the thin sauce that FCA used to chase that last tenth of fuel economy, I pivoted to that particular gear oil and haven't looked back.
Owning a JL-generation Jeep has been very instructive, in terms of discovering the many things a manufacturer will attempt, not all of which I like or would otherwise allow, in the endless chase for fractional improvements in average fuel mileage. The interwebs gets full credit for shining a light on such efforts, and how the informed owner may safely work around them and to the benefit of the vehicle's longevity itself.
zouch
Berkeley, CA
XJ, JLUWD
note that all of the preceding advice assumes stock components.
if you've updated to use something like an Eaton Gear-driven Limited Slip, they may recommend something else entirely.
bottom line; we need to look at what the manufacturers of our parts recommend; J**p is more interested in serving their own interests (warranty CAFE, etc.) than the longevity of our equipment.
If you have modified your jeep with larger tires, different gears, added weight, etc., your use may be more severe than the Jeep envisioned. So 75w85 in the front axle as Jeep recommends, may not be up to the job. Going with what Dana, the axle manufacturer recommends (75w140 GL-5) will provide more margin in the lubrication protection when the axle is subject to loads that Jeep did not design or test for.
