Differential Covers
Jgc650i
North Carolina
22 Wrangler 392XR, 22 Ram 1500 Lmtd, 24 Audi SQ8
Since Jeep in its infinite wisdom decided to remove the drain plugs on the front and rear differentials starting with the 2022 model year, thereby requiring the entire cover to be removed to change the fluid, I’m thinking of swapping out the covers for ease of future use. Of the various options, I’m leaning towards the ARB Covers. There is some conflicting feedback in the reviews for the front cover that it can be challenging to install, but rear is all positive. Wondering if anyone has any real-world experience with these covers and can offer any feedback? Or, alternatively, any recommendations on any other brands? In my case this will be for a 2022 JLU Rubicon 392XR. Many thanks!
Jeep Wrangler JL Differential Covers ArbDiff
Byrds8
2022 JLU Beach, 2022 JLU High Tide
Nice, guess Ill be doing this eventually also so I can change my own oil after these are put on.
Levin_tom
Tomas
Jeep Wrangler JLUR
I have the ARB diff covers for both front and rear on my 2020 JLUR. The install was pretty straightforward. I did not have any issues. My only complaint is that the bolts rusted pretty quick. I will prob switch them out soon. Happy to provide pics if needed.
Jeepin_Donnie
Donnie
Northern VA
18 JLUR, 23 Wildtrak Bronco w/Sasquatch package
Benefits Manager
I just purchased Motobilt diff covers. I'm going to paint the M red and then clear coat them. I like the look of the raw steel and welds. Very cool.
JRobes
Josh
South Dakota
2020 JT Max Tow, 2004 WJ Overland
Mech Engineer
don't have much to add to this, but was there a reason they removed the differential drain plugs from the bottom of the diff? seems like a huge misstep...
CarbonSteel
2023 Ford Bronco Wildtrak
Same; they are built like tanks:
Front:
Jeep Wrangler JL Differential Covers Front Skid + Cover
Rear:
Jeep Wrangler JL Differential Covers Rear Skid + Cover
CarbonSteel
Save a penny and potential damage by hitting them on a rock.
Jgc650i
Jgc650i
North Carolina
Thank you, that’s very helpful.
Roky
Roky
I kept it in house….. went with Dana.. and a Rancho skid, that I color matched……
Jeep Wrangler JL Differential Covers 4E196728-9CF4-4215-83E4-98880D9CCD48
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Plenty of reasons to change the factory diff covers. The addition of a drain plug shouldn’t be one of them. Any nasty bits in the housing will settle at the lowest point. The lowest point will never be on a diff cover. The cover should come off during routine fluid changes to inspect for wear and/or damage.
BDinTX
Dallas, Tx
I’ve got the ARB front and rear. I thought they were pretty easy to install and I think they look real nice.
I did have two issues though. On both Jeeps, the bolt holes in the diff housing that straddle the axle tube weren’t threaded deep enough. I needed to use a tap to get the new bolts all the way in. You may not have to do it but be prepared to.
One of the covers also had the wrong bolts with coarse threads included with it. Recommend pulling one factory bolt to compare threads before taking them all out.
This pic is after scwacking it on a rock and I ain’t even skurd.
Jeep Wrangler JL Differential Covers 86F0EEB7-ABAC-4D6F-86F2-978C175B8C9B
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I've had front and rear ARB covers for over 3 years and 65k miles. Very strong, still look good, and zero leaks. Don't see what would negatively affect installing the front vs rear.
Jeep Wrangler JL Differential Covers 20211013_132423
Jeep Wrangler JL Differential Covers 20220616_135517
  • Like
Reactions: J0E
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Jeep Wrangler JL Differential Covers 41042D9B-B30B-4959-B8BC-4E8F037689CA
Damn, for some reason I thought the Dana covers only fit the U44 axles. They look nice.
