Difference between the V8 vs V6 radiator ? Is it interchangeable?
Petey
Pete
Miami
2020 jl sport manual
It would be cool to know...
Petey
Pete
Miami
The 392 V8's radiator can travel 0-60 MPH in 4.3 seconds. The V6 radiator, not so much.
well to e honest, if i could find something that has better cooling capacity my v6 rad would fly out of the engine bay in less then 4.3 seconds @60mph
mwilk012
2018 Ocean Blue JLU Rubicon
Service
You must have figured out something the engineers hadn't considered, like ideal operating temperature.
Petey
Pete
Miami
Yes, like the time they engineered the exploding flywheel clutch combo or maybe the time they engineered the loose steering gears in the steering box . Or maybe, was it the time they engineered a very fragile plastic oil filter cover that guarantees an expensive replacement every few years because the base is made of the same material. My most favorite would be the easy access to the spark plugs though . This is something the engineers have been considering for a while. I f by chance u receive a bad plug .. think about it ...no consideration given . What worries me most though, is the 40 degree temp spikes that occur on hot days at stop lights.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Engineers aren’t perfect. And like most things, are bound by cost. That’s why unfortunate things happen.
Petey
Pete
Miami
So true
Engineers are indeed perfect. It's their management that are flawed. ;) ;)
Blade1668
Darrell
N Alabama
91MJ,90XJ,91XJ,05,LJ,05JT
Supposed to be a different grill and fan on JT I'm not sure what else. This is a picture of my JT's grill if that looks different
Jeep Wrangler JL Difference between the V8  vs  V6   radiator ? Is it interchangeable? IMG_20210216_162923~2
The Jalopnik article above shows the subtle differences of the grill. The slots are slightly wider and the grill screen is more open.
mwilk012
Service
The JT grille is exactly the same shape and size, the snap in covers have larger holes. They are interchangeable.
Petey
Pete
Miami
They are larger ...doubt this alone would fix anything as far as my experience tells me.
Odyssey USA
Daniel
www.youtube.com
Sahara
Well they have the diesel and might eventually put a 392 in the JT. If they do, it makes me wonder about the real reasoning for not offering the 2.0 given the cylinder pressure (and BTU’s) created by the other two at typical tow rpms.
