Diesel RPM on Highway
thance
New Jersey
2010 Commander, 2002 Liberty, Looking for JLURD
For those with the diesel, what is your RPM and gear when cruising on the highway at 80MPH?
thance
New Jersey
@AdvEddie was that 7 or 8th gear and are you running stock height, tires, Rubicon?
AdvEddie
Ed
Prescott, AZ / SF Bay Area
20 JL Rubicon EcoDiesel -15 Ram 2500 Cummins Mega
I would assume it was top gear, yes. Everything stock on Diesel Rubicon with factory BFG tires.
thance
New Jersey
Thanks. For those running 35s or 37s, do you see much difference?
BuffaloBill
WI
2018 Wrangler, 2014 Ram 1500 EcoDiesel 2020 JLUR Ecodiesel
Granted, my example isn’t using actual tire diameters, but roughly speaking, if a 33” tire-equipped Jeep runs 2000rpm @ 80, then a 35” would run:
(33 x 2000)/35 = 1886
37” ——> 1784
etc.
  • Like
Reactions: GtX
thance
New Jersey
That's the math, but does it actually do that or drop into 7th?
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
My JLURD goes into, and holds, 8th gear around town. Been using manual recently to keep RPM up some.
BuffaloBill
WI
I’ve only got 315/70/17 KO2’s ( that measure about 34 1/2”), but at 60 it holds 8th pretty well. With a Tazer to tweak in the speedometer to agree with gps, the tach shows 1500rpm. With enough headwind and mild grade it will sometimes drop to 7th. I can’t imagine it needing 7th at 80mph. Hopefully other diesel owners will chime in, having sustained that speed on an interstate and can offer first-hand 80mph data.
Bravo
Eric
Meridian, ID
2020 JLUR 3.0, 2016 Dodge Ram 2500 Mega CTD, 2019 Roadglide Special, 2015 Malibu Wakesetter 23 LSV, 2019 Skidoo Summit X 165, and 2018 Skidoo Summit X 154
37’s 8th gear 3.73’s approx 1800 rpm @80 mph
MeekoDiesel
Patrick
Raleigh, NC
2020 JLURD Sting Gray , 1948 Willys CJ2A , 1976 Chevy C10 , 1998 Honda Civic
Nuclear Operations Technician - Shearon Harris Nuclear Station
2k, 80mph, 8th gear. Pulls up grades at that speed in 8th no problem.
JL Eco Diesel
Dustin
Kansas
2021 JL Rubicon - 3.0 Turbo Diesel
yep right at 2k at 80 MPH. I only have about 300 miles on mine but it is an absolute beast.
