Dudley Dawson
- David
- Aug 17, 2018
- Northern Virginia
- 2018 JLU Rubicon
Thanks for the suggestions. I went with the Fox 2.0’s.
Those are good shocks. I have had them in my Ram for about 10 years and love them. Also, from what I can tell from the below chart, which I shamelessly stole from another JL Forum post...thank you @AnnDee4444 for putting this chart together. The Fox 2.0s (assume 2.5" lift) seem to fit the need very very nicely.Thanks for the suggestions. I went with the Fox 2.0’s.
Wow - that is a great shock comparison and resource (thanks @AnnDee4444).Those are good shocks. I have had them in my Ram for about 10 years and love them. Also, from what I can tell from the below chart, which I shamelessly stole from another JL Forum post...thank you @AnnDee4444 for putting this chart together. The Fox 2.0s (assume 2.5" lift) seem to fit the need very very nicely.
I was a bit hesitant as well...but IRL it looks amazingly good. I actually think it could go another .5 inches front and back and still look great with the 35s. To me at least they don't look small for the wheel well space. As it sits now I simply could not be happier with the look. I think you will love it.Wow - that is a great shock comparison and resource (thanks @AnnDee4444).
I was a bit apprehensive about going 2.5 with 35s (as in excessive fender gap) but the Gray JLU D on Clayton’s webpage with the 2.5 lift looks awesome (albeit with non-Rubi fender flares). But I like having added space for articulation anyway.
I “just emptied every pocket” after promising the wife 2 years ago that the Rubicon was the ideal choice, because I wouldn’t “need to” add mods etc. Oops.
Anyway - awesome build. Sorry for hijacking your thread but looking forward to seeing your results.
Radflo and ADS shocks have great options for JLs. ADS' have great specs.Those are good shocks. I have had them in my Ram for about 10 years and love them. Also, from what I can tell from the below chart, which I shamelessly stole from another JL Forum post...thank you @AnnDee4444 for putting this chart together. The Fox 2.0s (assume 2.5" lift) seem to fit the need very very nicely.
Excellent write up! So happy to hear you great time! Sign up for Camp Heep and join us at Rausch Creek! It's a great event. Please PM me anytime if you need anything or have any questions. Thanks!I finally have the Jeep back. Picked it up from OCD Offroad at about 8pm last Friday, and was off to run Flagpole with NOVA Jeepers at 0630 Saturday morning. A big thanks to Scott at OCD, he had a busy week but still got the work done and then stuck around 1.5 hours after close time to walk through everything with me, go for a long test drive, and do a final check on everything. Also thanks to @Jeepin_Donnie and the NOVA Jeepers crew for putting together a great day out on Flagpole!
Suspension: 2.5 Clayton Overland + Diesel
Tires: 35" Toyo Open Country AT II
Wheels: Method 701
Inner Fenders: Metal Cloak
Fender Brace: Metal Cloak
Shocks (temporary): Metal Cloak Rocksport long travel
When the Clayton kit (@Clayton Off Road) originally went in it was good...but had room for some tuning. As installed out of the box, with no tuning or additional mods I had about 10 inches of travel (at the shock) in the front and just a touch more in the rear, about 2.5 inches of up-travel (before contacting bump stops) in the front and a little less in the rear). While these numbers are not bad, I was looking for improvements in both. So Scott and his folks at OCD started working to improve those numbers.
The first thing we did was pull out the OEM inner fenders and fender liners , install Metal Cloak front fender liners and fender braces, and then re-ramp it. The gain was exceptional. Just this change gained over 3 inches of space in the wheel well. This allowed all 3 inches of Clayton added bump stop to come out and gave me 5.5 inches of up-travel. However, as configured the swaybar arms were contacting the inner fenders. So we started trimming the sway bar links a bit at a time to see if we could correct this. In the end we corrected most of it with trimming links, but had to add 1 inch of bump stop back in. This solved the problem on the ramp...but at is turns out not completely on the trail (will continue to work this issue over the next couple weeks.)
The final numbers were
Of note there was still some room left to go before tires made contact with anything. However, as you can see from the pictures, at those numbers my back tire was starting to climb the ramp and the jeep was getting a bit tippy. It looked like the front had about another 3/4 - 1 inch to give and the back maybe another 1/2 - 3/4 of an inch. So, I think an assumption of 13 inches in the front and about 12 inches in the rear is good....and I am happy with those numbers, in fact extremely happy with those numbers for a mid-arm bolt on kit.
- 4.5 inches of up-travel (before contacting bump stop...will compress a bit from there)
- 12.5 inches of travel (measured at the shock) in the front (18" compressed - 30.5 inches extended)
- 11.25 inches of travel (measured at the shock) in the rear (21 3/4" compressed - 33" extended)
Performance out on Flagpole (pretty easy trail), was exceptional. I tried to take the hardest line through every obstacle. The combination of the low RPM diesel torque, lockers, and the very flexy suspension meant that I essentially idled through every obstacle without losing traction a single time. Now, Flagpole is pretty easy, but still I was extremely impressed by the performance of the JLURD. I did have a couple minor teething problems. I had a few jam nuts loosen up and most significantly, the bolt on my passenger side upper control arm lost a nut and backed out half way. I found it at our mid-point stop when I checked all the suspension components. Again the NOVA Jeepers crew were outstanding. Josh dug out a nut from his tool kit and our group tail contributed a high-strength ratchet strap...in short order we had the control arm aligned and bolted back in place...no drama, but can't say enough about how good a group of folks the NOVA Jeep crew are.
An easy section of Flagpole where I was able to focus more on taking pictures than driving.
Mid-point stop
So, overall still a couple minor issues to work out with the current set-up, but very pleased with where the Jeep is at the moment. The next step is to start working with Radflo (@Radflo Shocks) and figure out what the right shock set-up is for me...then order a set of 2.5 inch Radflos to top off the suspension. Then on to the next project....
We almost got done installing Metalcloack 3.5” Gamechanger this weekend, and could not finish because our e-brake cable was too tight to hook back up to the driver side wheel! I am gonna look into this synergy emergency brake cable bracket!Two quick additions to the Jeep last night. I put in the synergy emergency brake cable bracket to facilitate re-routing my brake cables under the frame brace (see pics). When at full extension the OEM mounting over the top of the brace (blue arrows) was causing my driver's side rear wheel to drag a little and my passenger side rear wheel to lock completely. This should resolve it, re-routing with the bracket gained about 3 - inches of travel.
Did you lift the console up and let out some slack? Probably 1.5 to 2.5 inches of available adjustment there. Pull two lower side bolts out from back of console, lift console up and the adjustment mechanism is right there.We almost got done installing Metalcloack 3.5” Gamechanger this weekend, and could not finish because our e-brake cable was too tight to hook back up to the driver side wheel! I am gonna look into this synergy emergency brake cable bracket!
No, since the MC instruction did not include e-brake adjustments. We ended up fishing the e-brake lines back and under the bar they were mounted above. Now we have quite a bit of slack and the e-brake feels soft/too easy to pull. Will definitely take a look at what you described here! Thanks!Did you lift the console up and let out some slack? Probably 1.5 to 2.5 inches of available adjustment there. Pull two lower side bolts out from back of console, lift console up and the adjustment mechanism is right there.
