Themistocles
So projects have been building up a bit. As of this morning I had an MBRP muffler delete, back-up & chase lights, and a Quadratec Stealth 10k winch (@Quadratec) sitting in my garage waiting to be installed. I also have the new Oracle (@ORACLElights) flush mount taillights ordered, arriving early Jan...should be one of the first 100 or so installed. The back-up and chase lights I will do at the same time as I put in the new taillights, so those can wait. The winch would have taken me more time than I had to spend this morning...so it was the MBRP muffler delete that got installed.
MBRP Instructions were simple...remove old muffler, install new pipe (ok there were not quite that simple, but not far from it). The reality was a little less simple.
As instructed I first removed the clamp holding the pipe and muffler to the rest of the exhaust system. I first sprayed it down with a little bit of penetrator, and tried a 3/8 inch drive ratchet on it (nut is 5/8). It would not budge and no room for a breaker bar. Switched to a 1/2 drive ratchet...same result. So pulled out the impact wrench...that did it. Bolt was off in about 30 seconds.
Next was to pull off the muffler. That was not quite as easy as I had expected. The two hangers are pretty tight and they each prevent the movement needed to remove the other. In the end I came to the revelation that one of the hanger brackets is bolted on (driver's side front hanger). Once I figured that out it was pretty easy.
With the bolts out I had to twist the hanger bracket 90 degrees to clear the DEF tank, then remove it. With that hanger out of the way, the passenger side rear hanger was fairly easy, just took a little twisting and some leverage and the hanger came out of the rubber mount.
The install was smooth. The MBRP does not have a driver side front hanger so I did not re-install that mount. The pipe fit cleanly and easily and the passenger side rear hanger took a little twisting and some leverage, but it popped in without that much effort.
It is very solid, tucked up well out of the way, and looks great. I did video clips to capture sound at idle before and after. I can post if anyone is interested, but truthfully I cant tell any difference at idle. Maybe just a bit more of the diesel rattle, but that could well be my imagination. Will see what it sounds like at speed, but I suspect with all the emissions stuff, the muffler is mostly irrelevant. Project took about 1.5 hours from the time I decided to do it, to the time my tools were put away and I was back inside with a cup of coffee.
I was hoping that the OEM muffler would be a bit heavier...as every pound counts in the JLURD. Really I think the difference between the OEM muffler and the MBRP product is probably 6 - 8 lbs. Now that is not nothing, but i am not sure that 6 - 8lbs of sprung weight justifies the project. However, lower weight, a little more diesel sound, maybe a touch freer flowing exhaust, and a cleaner look with some space created, all together I think that justifies the 115$ the MBRP pipe cost. Will give it a little road and trail time and report back.
EDIT 12/14 - Have been driving for a couple weeks now. Overall, I was surprised that it actually did seem to have some impact. I drive the same route in to work most days and have become very attuned to the mileage I get. I seemed to have jumped about .2 or .3 MPG, and gained a little seat of the pants felt power. It is possible that there is something else causing the change...but sure can't think of what that would be. I have noted no change in sound from idle up to 80 mph.
