Will wrap adhere to the black fenders?I have the standard black fenders and hardtop and I am considering wrapping them to match the body. Has anyone done this and how has it turned out?
If you haven't experimented with Plasti-Dip -- you aren't living naw but srsly it's great stuff and very durable. Only trick is make sure you get enough coats on. Most people using Spray Paints like to put on lots of really thin coats, so it doesn't run or look too spotty. Do that, but make sure you get enough complete coats on there. Otherwise it makes it more challenging to pull off when you want to some day. Also, you can spray more on top to thicken it up, even if it's from an older job. You can also texture on top of the plasti-dip, I did most of my emblems with a few coats of plasti and a few coats of truck bed liner to match. It's very cheap and easy to DIY, so it might be worth looking into vs. a full wrap. Good luck!I asked the same question to a wrap shop. They said that it would not adhere, and would pull off easily. Recommendation was a full plasti-dip, but I can’t see that being very durable.
