DEF IND Recall, Y81
Parratt
Logan
Edmonton Alberta
2020 JLUD, 1988 MJ, 2010 XK (Sold)
Anyone have more info on this?
Jeep Wrangler JL DEF IND Recall, Y81 received_5185241541525943
BroncoHound
Bud
Meridian, ID
2020 JLUR / 2022 JLURD
Taxi driver-in-training
Haven't I read a few places where folks were having an issue offroad where they'd fire up their Jeep and would get a false indication that the DEF was almost empty when it wasn't? I'm betting that is what this will end up addressing. Maybe a new float valve in the DEF tank or maybe just a software update or something.
All just my speculation since I don't see anything posted online about a Y81 recall yet.
SolarWizard
San Diego
Nacho3lJT
Owner @ Solar Co
I suspect the pump is dumping DEF too much which is why some people get such terrible mpg of DEF
Horsemover
Jamie
NW PA
2021 JLURD / 1997 TJ 4.0
Under the parts section It mentions a DEF injector needed.
Terpsmandan
Penn Yan
Start date was 1/19. DEF inducement issues. My wife's '21 JLURD does not have that code coming up as an issue. IMO I agree it's something in the DEF pump.
Compression-Ignition
Roy
Montana
2020 JLUR 3.0 Diesel, 2020 6.7L F350
No codes for me. But man can you smell the DEF being injected.
545moose
Jon
Ashburn, VA
GX460
Saddle Tramp
Mitch
Hays NC
2021 Rubicon 3.0 Turbo Diesel
I have an appointment for the Y81 Wednesday at 1:30. I was under the impression from the service booking agent that it was just a re-flash.
I will let you guys know how I make out.
brewski
Jack
Washington
JLUR-diesel
I follow Casey250 (canadian) on YouTube. He has had some issues with diesel. From what he has said on his channel, he burns DEF up 2x or more faster than I do and hes had issues with the jeep not starting because it thinks the DEF tank is empty when it is half full. Probably fixes these issues.
I watch my DEF level on my Banks iDash, and it fluxuates a lot, 20-30% difference for min/max. Clearly the sensor is in the back right because it will drop a little on right turns and drops a lot when parked downhill. I've been watching it because of the issues he's had.
Saddle Tramp
Mitch
Hays NC
OK just got back from the Y81 recall seems it was just PCM re-program. Covered under warranty.
Only cost me a windshield - I saw the rock comming even ducked - like that would make a difference.
Does anyone know if you can get a replacement that doesn't have a rock magnet? This is the second big hit in 2 weeks.
Om4r
Omar
Boise
2020 Jeep Wrangler Sport S EcoDiesel
just got a call from my dealership. They just want to reprogram the PCM. They got a mobile unit coming out next week. Hopefully it doesn't change the consumption of it. I'm not using a whole lot of it.
