zeebo56
- Zee
- Mar 8, 2020
- los angeles
- 2020 jeep wrangler unlimited sport
- Vehicle Showcase
- 1
I have a 2020 JLU sport S. I was on the freeway at around 70mph about a week ago and there was a bumpy section of the highway. The jeep started shaking like crazy and I thought the driver side wheel was going to pop off.
So I am not sure if the death wobble is related to having my Rancho front adjustable track bar installed or not. But I hadn't felt any significant bouncing or death wobble for 8k miles until I did the adjustable front track bar.
I had to extend the adjustable track bar out about .75" longer than stock to try to get my passenger wheel to stick out past the fender the same as the driver side. Maybe that is causing the problem?
My suspension consists of:
Rubicon take off springs and shocks
Mopar longer LCAs non adjustable
2.5" rough country spacer lift kit
35" milestar patagonia tires on Edge 17s
Rancho Rear adjustable track bar which was kept close to stock length
And recently in the past couple weeks the Rancho front adjustable track bar but extended a little over stock.
Drag link was adjusted to center the steering wheel and I did a slight alignment with the toe.
First 8k miles no issues with most of the other components until I did the front track bar a couple weeks ago. Also seems like in general the ride is a little bumpier. But the death wobble really freaked me out.
I don't think any other parts have failed. I was wondering if the steering stabilizer should be replaced at this time or is there something else you would suggest?
thanks
thanks
