Deal of the Week!
Status
Not open for further replies.
RebelOffRoad
Evan
22551 Shannon Circle, Lake Forest, CA 92630
www.rebeloffroad.com
2018 Jeep Wrangler JLU / Jeep Wrangler Rubicon 392
Jeep Builder
Trailgater for the JL!!
Get yours HERE!
$345 w/free shipping!
Price includes cutting board! JL Trailgaters will begin shipping May 29th.
The JL Trailgater is engineered specifically for the 2018 Jeep JL Wrangler and replaces the whole plastic inside tailgate cover. It utilizes the same proven design used for our JK Trailgater, has a larger table and cutting board and mounts to the JL tailgate using 9 proprietary injection molded blind nuts. The JL Trailgater also keeps available the 3 mounting points in the center of the tailgate.
The Trailgater is designed to be extremely functional, ergonomic and to look fantastic on your JL Wrangler.
Stop preparing your food in the dirt.
When out on the trail, most of us Jeepers end up serving snacks and meals from the top of a cooler. Quite often, part of the meal ends up in the dirt. The Trailgater is designed to get both you and your food out of the dirt.
Whether serving trail snacks or preparing a full meal, the fold down Trailgater utility table can handle your needs. Its large working surface provides ample room for a camp stove and still have room to place cooking utensils, mixing bowls, plates, cups, containers and such.
The slide out cutting board enlarges the working surface when needed for cooking, chopping, mixing and preparing food.
The Trailgater is also a great working surface, field desk, or just a great place to keep your tools while in the middle of a repair.
  • 10 minute or less installation. No drilling required!
  • 1.8" of depth from the tailgate when stowed.
  • Stainless Steel hardware used throughout
  • The bamboo cutting board conveniently slides under the table and the assembly folds up and is held in place with two rattle free spring latch pins.
  • The table is 25" x 14.5" and the slide out cutting board is 12" x 20" for a combined 600 square inches of surface area.
  • 14 gauge (0.075") food-grade Stainless Steel, the backsplash is 0.120" powder coated Aluminum, both are CAD designed, laser cut, CNC bent, and deburred.
  • Max weight capacity is set at 40lbs.
Status
