Dead battery. Jump start?
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
My daughter left her heating blanket in the on position. So ....a few moments later...actually a few days later my battery was completely dead! Can I jump start it as you would normally jump start any regular vehicle or is there some precautions I should take prior to jump starting. Thanks!
Radioman
Kent
Roseville, CA
2017 Toyota Highlander, 2020 Ford Ranger, 2025 Jeep Rubicon
Retired Public Safety Communications Manager
If the battery is totally dead, it probably will need to be replaced. I would put it on a low amp charge for a few hours before tying to start it.
Oh, Happy New year.
Heimkehr
Pennsylvania
2021 JLU 2.0T
I recently jump started an engine with a battery reading 10.x volts. Insufficient to start the vehicle by itself, but not completely discharged, as you claim the battery in your Jeep is. If the volts are truly at or near zero, I wouldn't attempt a jump start. Either connect a charger in an attempt to resurrect the drained battery prior to a jump start attempt, or better yet, replace it with a new one for peace of mind.
jromanmd
Jon
Annapolis
2023 Jeep Wrangler Rubicon
Here you go. It's in the owners manual or you can go into a filtered search on Google.
Jeep Wrangler JL Dead battery. Jump start? jump1
Jeep Wrangler JL Dead battery. Jump start? jump2
Jeep Wrangler JL Dead battery. Jump start? jiump3
m3reno
m3reno
Sal
caldwell
melendez69
Marc
Waxhaw NC
...huh?
rk911
Rich
DuPage County IL
'23 Wrangler Sport 2D, '10 Liberty, '46 Willys
Retired and loving it!
Oh, Happy New year.
Overnight would be better. And if it's NOT a sealed battery you might want to check the fluid levels in the cells before charging.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Aren't all JL starter batteries AGM?
rk911
Rich
DuPage County IL
I don't know and I try not to ever assume. I offered the suggestion as I have no idea what battery the OP has.
m3reno
m3reno
Sal
caldwell
Well, this charger worked for me in the past when the battery was partially dead. But it does not charge a completely dead battery! Any recommendations?
Nokones
Kenny
Sun City West, AZ
Since, the battery is an AGM battery it should be able to be recovered with a quality smart AGM Charger. A smart AGM Charger will properly recover a completely discharged AGM battery. A standard battery charger will destroy an AGM battery with the charging process.
