chachimcnacho
For those of us in states that partake, this weekend is Daylight Savings Time. Since we get an extra hour, what are your suggestions for mods that can be done in less than 60 minutes?
Came to say this as well, just did mine today. 39 minutes from walking outside to back in lolLed headlights. It gets darker earlier.
Yes, unfortunatelyLed headlights. It gets darker earlier.
thats a great picture showing the headliner working the way it was meant too!Well...not the Mopar LEDs. The headlamps can be swapped in 30 minutes, but rewiring, hooking up and activating the halos takes half a day of work...
Adding a headliner can be pretty quick, and should help retain the heat inside the cabin.
On the photo below: the areas that are iced over have headliner underneath; the bare areas do not.
Is that just for looks or does it make the shift easier?The B&M extended t-case lever
Functionality.Is that just for looks or does it make the shift easier?
It both extends the lever and angles it towards the driver and a bit forward. It makes it easier to grab and its extra leverage gives more control to avoid overshooting the mode you're wanting.Is that just for looks or does it make the shift easier?
