Dash Warning - Vehicle Speed is Too High to Shift to P
cjsam2004
Wisconsin
Has anyone seen this error before?
Not sure what happened, but ever since I drove in 4L mode last night and parked in my garage back to 2h mode. It makes this weird transfer case noise along with the above warning when in reverse or drive mode under 2h.
My guess is its auto locking but why ????. All the doors were closed, and the seat belt was on. Planning to tow it to the dealership tomorrow but wanted to see if anyone else experienced this.
Thanks,
CJ
Kevin Mojito
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
It looks like the dash thinks it's in 2H, but sounds like it's not engaged all the way. Have you tried pulling the t-case back into 4H, then back to 2H.
cjsam2004
cjsam2004
Wisconsin
I tried it again and interesting enough it only allows me to go back to 4L (at which point autopark gets disabled default) but going into any other mode (2h or 4h) it makes that transfer case noise with that dash warning. Wondering if its ok to drive in the 4L mode to the dealership under normal conditions.
Kevin Mojito
Washington
will it move in any mode ( 2H 4H or 4L ) ?
You could do it. it will bind up pretty bad. Not recommended. It sounding like the shifter is out of adjustment on the t-case.
cjsam2004
cjsam2004
Wisconsin
Yes, I can drive forward or reverse in only 4L mode.
Kevin Mojito
Washington
ok, for sure the shifter lost adjustment.
To cover yourself, I would call dealer service first. Tell them you only have 4L working. Drive or flat bed tow? Have them make the call. I have never had any problems driving in 4X4 mode on street, that's not to say you will not either.
cjsam2004
cjsam2004
Wisconsin
Good point. I’ll give them a call first. Thanks for the advice.
redsyphon
North Florida
2018 JLU Rubicon
IT Project Manager
Just curious if you ever got this resolved/what the root cause was.
