Very cool. Very professionalJust passing the time until they make a lift for my 2 door.
On vinyl with a printer and a cutter.Cool! how'd you make it?
every single lift for a 4 door will work with a 2 door there are zero differences !! the only thing that you have to to take into account is your drivesfaft angles so unless you go taller then 3" you dont need to wait for a kit that claims its specific to the 2 doorJust passing the time until they make a lift for my 2 door.
You don’t think the spring rates are different?every single lift for a 4 door will work with a 2 door there are zero differences !! the only thing that you have to to take into account is your drivesfaft angles so unless you go taller then 3" you dont need to wait for a kit that claims its specific to the 2 door
that's really cool I can do those too.Got this from Hauk Offroad
60" graphtecWhat cutter do you have? If you don't mind me asking.
This statement is not accurate, as it pertains to a JL.every single lift for a 4 door will work with a 2 door there are zero differences !! the only thing that you have to to take into account is your drivesfaft angles so unless you go taller then 3" you dont need to wait for a kit that claims its specific to the 2 door
There are indeed several different spring rates. In fact, it has been demonstrated that stock JL spring rates are also different from passenger side to driver side, and are color coded from the factory.You don’t think the spring rates are different?
