Dash light going on and off
LLRubylady
Lisa
NY
was an ‘18 Rubicon Mojito! now a boring Mazda
noticed the past 2 days the dash brightness light goes off and on every once in a while. It’s weird. Is there a sensor or something causing this? I have headlights set to auto.
Or a fuse maybe?
DaltonGang
Houston, Tx
It is supposed to do that. It switches to night mode, in dim and cloudy days.
You will notice your headlights will be turning off and on, when this happens.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Mine did this just yesterday
old8tora
Cali
2016 JK Sport
Or a fuse maybe?
Can you disable the "auto" setting ?
BillG
Bill
Middle Tennessee
2018 Sting Gray JLUR / 15 Harley Tri glide / 50 Dodge Rat pickup
Yes you can just turn on the headlights manually if you don’t want to use the auto setting. You’ll still have the daytime running lights though, which are almost bright enough to drive at night with.
There’s a few minutes in the morning and afternoon I’ll sometimes turn them off auto, so they won’t be coming on and off when I drive through the shade. The off on flashing then probably annoys someone ahead of you.
lookitsadam
Tampa, Florida
2018 JLU Sport
Auto headlight setting can be disabled by turning the headlight dial off of auto, obviously. To disable the dash lights from automatically dimming when the headlights come on use the vertical dial next to the headlight dial.
