Dash cam rear camera install tips?
Scarr2k
NC
19 JLUR
Picking up a front/ rear dash cam and wanted to see some ideas of how folks mounted the rear camera specifically when running a soft top? I was thinking in the middle of the back roll bar but wasn't sure about how to run the cabling from the front windshield to the rear. Any tips or suggestions? Thanks!
kimmonia
Midwest
2019 JLU Rubicon, 2018 Ford Explorer
Need solutions for this too! Hate to get a dash cam with rear view and only get full use of it when with hard top.
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
I just ran a rear cam wire on top of my sound bar. Wanted to throw you a bit of caution and testing, before you do your final wiring: with my camera wire in either top or bottom of the soundbar, it completely interferes with the XM antenna. You might want to test that before you run your wire. Just "mock" it up or hold it to where it will sit and check for interference. Besides that little snafu, my spare nearly negates any use for a rear cam - lol
Scarr2k
Scarr2k
NC
19 JLUR
  • Thread starter
  • Thread Starter
  • #4
Thanks, that was what I was hoping to hear from folks if the spare tire pretty much blocks any view. I am now leaning towards just putting a front dash cam and not worry about it or pickup a front dash cam with the front/rear cam built in. At least it would catch the side windows and cabin. Something like the Anker Duo Dash cam.
jlewissystem
J
STL
I think the spare consideration def depends on the size of spare. You would get more video coverage with the stock or even 35. I am running a 37, with an adjustable spare bracket, so it's bigger and sits higher.
Scarr2k
Scarr2k
NC
19 JLUR
  • Thread starter
  • Thread Starter
  • #6
Just put in an Aukey dual dash cam. Wasn’t too terrible to install even running the rear wire through the roll bar area. Both the front and rear have 1080p and I think it gives enough view out the rear window. I basically centered it behind the interior light. The lens allows for enough positioning where you can get a good view.
Also I was able to tuck about 5-6’ of rear dash cam cable up in the rear bar in case I decide to move the cam if I run the hard top at a later date and want to glass mount it.
Couple front/back snaps when driving.
photogoose
Maryland
2019 Mojito! Wrangler Sport S Unlimited, 2009 Hyundai Sonata
What did you use to attach it to the roll bar? This looks like a decent setup. Hows the camera working so far?
Scarr2k
Scarr2k
NC
19 JLUR
  • Thread starter
  • Thread Starter
  • #8
Just used 3M tape that was provided. Holds tight and hasn’t come loose.
I will say I had a lemon on my first Aukey purchase but returned and got a new one and it’s worked perfect. I do like the motion detection if you keep it powered it works quite well when parked.
photogoose
Maryland
Thanks for the reply!
how are you powering it? hardwired/with the ODB kit, or off a battery pack?
Scarr2k
Scarr2k
NC
19 JLUR
  • Thread starter
  • Thread Starter
  • #10
I’m using an OBD connector. Aukey sells one for the camera, but I’m actually using one from Anker that works well (few bucks cheaper) and hasn’t given me any issues. Also has the ability to shut off when the battery gets too low.
Anker Roav 6 ft USB Hardwire Kit, 24/7 Parking Mode, Low Voltage Protection, 12V-30V, Easy Installation Into Vehicle OBD, Compatible with Roav DashCam Duo
photogoose
Maryland
