rkwfxd
Do you have a part number for the RCV inner/inner shaft? I'm not finding it on their site. TIA
Indeed I do:Do you have a part number for the RCV inner/inner shaft? I'm not finding it on their site. TIA
Thank you Sir.Indeed I do:
The inner shaft is D11351 and is $375
The FAD collar is D11418 and is $145
You have to call in to order it:
RCV Performance Customer Support
RCV Performance Products
1500 11th Avenue
Rockford, IL 61104
Ph: 815.877.7473 | Fx: 815.965.4857
[email protected]
I was waiting on the Fox DSCs to show up (and they have) I am planning to get them installed within the coming days.Any update? Did you get them installed?
Thank you.I was waiting on the Fox DSCs to show up (and they have) I am planning to get them installed within the coming days.
Very nice work!!!**Update**
They are installed! I did this in conjunction with installing Fox DSC front shocks so this was an all day event.
I had no issues with the installation aside from the passenger spline shaft was pretty snug in the hub bearing, but otherwise, all good. Both sides turn as freely as the OEMs did and the clearances between the two shafts on the passenger side are the same as the OEM.
No issues with turning clearance (the yokes are tighter going through the knuckle than the OEM, but not as bad as RCV CV's) and all in all a smooth install. A tip for those doing this is to rotate the inner shaft (after pulling the outside passenger shaft) until you can see both ends of the circlip on the shaft. Using two thin bladed screw drivers, push on both ends at the same time and it will just pop off. I ran out of time and did not get to drive it, but I plan to do that after I install the rear Fox DSCs.
@rkwfxd + @Spencer + @roaniecowpony + @blnewt + @chevymitchell + @BuyHold + @BadA$$Rubi + @word302 + @Howardlv22 + @mwilk012 + @OBJLU +
A few photos:
OEM shafts +FAD collar (before removal and you can see the gray plastic bushing):
RCV Inner Shaft and DS Outside Shaft + FAD Collar (with its bronze bushing):
Passenger Yokes (from behind):
Driver's Yokes (from front):
Yes and all 4340 Chrome Moly too.
I have not driven it at all yet. Work has been busy and the temps outside have been below 10°F in the mornings. I need to finish the installs of the Fox DSCs in the front--I need to modify the MC lower mounts and am waiting on some rotary bits (for a little die grinder work) as well as some button head bolts to arrive.Any update since the install? I know there hasnt been time to put a lot of miles on but… any weird noises or concerns?
The MC mounts are related to the 2.5" Fox DSCs. I need an offset to keep the shocks from hitting the frame at full droop and the "knobs" at the bottom of the shocks are hitting on parts of the MC mounts and one of the bolts.Do the larger u joints interfere with the lower MC mounts???
