Call911man
- Kent
- May 5, 2020
- California
- 2019 JLUR
Hello everyone,
I was able to get this spec sheets from DANA today.
M210 and M220 are included below.
If you need anymore specs, you can reach out to Dana below:
Another member posted these sheets, as well. A couple are duplicated, but there's more data here: https://www.jlwranglerforums.com/fo...-gear-torque-and-tqtr-specs.22854/post-710999
Have you guys noticed the difference between what DANA shows on the two PDF files and what others are quoting here and elsewhere? The difference on quoted backlash is significant. I spoke with a gear tech yesterday and he stated that he would only use these tight specs for Genuine DANA gears. Also, it is very easy to find the spec sheets from DANA. search for differential type and click the "Literature page"Hello everyone,
https://www.danaaftermarket.com/
M210 page:
https://www.danaaftermarket.com/spi...0&str=M210&cp=0&catalog=PIMS_NA&partType=PART
Per DANA PDF for M210:
Ring Gear Backlash ................................0.003” – 0.006”
