DANA 35 (M200) HD Differential Cover
Hootbro
Don
Delaware
2018 JLU Sport, 2022 JT RUBICON
Thought I would share and show a few pictures of the recently release DANA 35 Advantek Heavy Duty Differential Cover.
Received mine directly dropped shipped from Spicer/Dana about a week ago. Includes the mount bolts with pre applied locktite and a tube of gray RTV. Installed it on my Sport S and decided to reuse the factory formed gasket that so far has been drip free. I did not have access to a published torque spec on the bolts but finally installed them at 27 ft-lbs. Tried 30 ft-lbs but it felt like the bolts were going to stretch and break, so the back off to 27 ft-lbs for final install.
Refilled to the low pinion hole with approximately 1.6 quarts of a full synthetic 75W-90 gear oil. I do not think any additional capacity is gained with this cover.
Mud2Sno
Mickey
2018 JLUR Rubicon
I ordered a set for my DANA44 on my rubicon today as I hit my front diff cover over the weekend and the stock lower bolt doesn't look very good, did you use any sealant or just the gasket?
Hootbro
Hootbro
Don
Delaware
Just reused the gasket. So far, no issues.
VNT
Maine
SRT Challenger, 2015 Hemi Overland, 02 WJ 4.7, 2000 Durango, PT Cruisers, 2018 Punkn Sahara 2020 OB Rubicon
Why do they have 2 fill ports?? which one do you fill to? Curious. Also is there a drain port on the bottom of the housing, my wife's Sahara is on order.
I just changed the gear oil this weekend in her Overland, nice having drain plugs instead of having to remove the covers, PITA on my WJ and Durango.
WXman
Central Kentucky
2018 Wrangler Unlimited
Yes there are drain holes on the housings front and rear. Very nice touch.
I also love that they ditched the rubber fill hole plugs, and switched to actual threaded plugs.
Babeinsap
Abe
North carolina
2021 JLU Sahara Altitude; 2001 TJ
Are you sure they have a bottom drain plug? I don’t see it in the photos
Hootbro
Hootbro
Don
Delaware
Starting sometime in the 2021 model year, they deleted the drain plug. You have to remove the cover to drain them now.
word302
Oregon
JLU
There are plenty of axles that don’t have a drain. It’s always a good idea to do an inspection when draining/refilling. Drain plugs just get hammered in the rocks anyway.
