Damper replaced and still have the Death Wobble
LadynKy
Yolanda
Louisville, Ky
2019 Jeep Wrangler JLU Moab
so has anyone else had their damper replaced and is still getting the death wobble? If so what is the next move from FCA? I just want to drive and enjoy my Jeep.
JeepCares
Auburn Hills, MI
JL
Hi LadynKy,
We're very sorry that you are still experiencing this. Please send us a private message if you would like to continue working with your dealer to resolve this. We would be happy to have a case escalated in your behalf.
Lydia
Jeep Social Care Specialist
JIMBOX
JAMES
FERNLEY NV
RETIRED
I'm sorry if this has been repeated SO MANY TIMES, BUT---
The steering DAMPNER(SHOCK) really has nothing to do with DEATH WOBBLE" the DAMPER is only a "bandaid/crutch" and buying more expensive DAMPER'S including DBBl damper's, won't cure the front suspension troubles !
I haven't had any trouble with the JL, but with my '08 JKUR, I DE-CLAMPED the steering DAMPER and drove for more than two weeks----NO DIFFERENCE IN STEERING--the DAMPER is just like a "SAFETY" VALVE in the steering system--
W.E.
JIMBO
Kent5
Kent
Las Vegas, NV
1999 TJ Sport
Tech
What mods have been made to your JL? Lifts? Tires?
Death Wobble on totally stock low mileage JL's is not unheard of but it is much more common on modded Wranglers.
List of mods might be a good way to elicit more helpful responses.
PavementWarrior
CA
2018 2 door JL
W.E.
JIMBO
partially true on a JL, and totally true if you mean true wobble vs a high speed shimmy.
if you have bad alignment, worn out bushings, tires needing alignment, loose front end bolts, lift messing up angles you must address those issue to fix both wobble and shimmy.
Right now we have some amount of "within spec vibrations" pushing the likely soon to be recalled "Steering assist" program to get into a "shimmy state". People are replacing stabilizers (some are defective) and gear boxes, in most cases its keeping the feed back to steering assist program from going non stable (pushes us just out of region where software starts over correcting)
Some people have already figured out disabling steering assist made the shimmy stop magically as well (dont do this other than to identify computer is mad at sensors, and some people discovered bad cal data was put into some 4 door also making steering assist do weird things).
You can bet there will be a software update, but in all cases we will have to keep alignments, bushings etc all in primo condition as well.
PavementWarrior
CA
2018 2 door JL
Serious question: How many people have died from the so-called "death wobble" in a stock Wrangler?
we are unlikely to know, it will simply show up as Wrangler shot off cliff. Dead men tell no tales.
We want FCA to fix it so lawsuits dont shut them down and we cant buy new wranglers in a few years
Kadonny
Malvern Pennsylvania
2018 JLUR Manual Trans Front Spacers, 2010 JKU Wrangler Sport
W.E.
JIMBO
Agree with Jimbo completely, and I don't know how many times that I've said what the JL is experiencing IS NOT true death wobble, it's more of a steering wheel wobble. But some people will see a shimmy and jump right to the death wobble term.
PS. For the steering damper replacement on the JL, I think there is now a TSB for it. I just had mine replaced and it got better, I'll wait to see how long it lasts.
Spartan99
US
2008 JKUX
If your Jeep is stock and has low miles, it’s likely an unbalanced wheel. Most Jeeps will get it eventually.
Do you have a lift?
Stock tires?
Do you offroad?
JIMBOX
JAMES
FERNLEY NV
RETIRED
A main cause of "DEATH WOBBLE" in the JK jeeps--after tire balance/toe-in/uneven tread wear was eliminated--has been --
Tie rod bushing abnormal wear--well that's pretty rare in a NEW JL, so-
There has been, a small percentage of LOOSE/UNDER TORQUED--BALL JOINTS--
It's a jungle out there--
JIMBO
84jeepjohn
24 JLUR 392 (soon I hope), 84 CJ7, 2005 Z71 Burb
I think "death" means it will scare you about to death when you get it. I have developed it in my CJ (I know it's either the Ball joints or wheel bearings, since I've replaced everything else up front. FYI they are the original 1984 BJ/WB and I've DD it since I got it in 01..on 35's so yeah I've been meaning to do this for quite a while) I know what causes mine to happen so I'm just waiting till warmer weather to fix mine. When I hit the right bump it is about the scariest thing I have ever seen!!! seriously NOT FUN
LadynKy
LadynKy
Yolanda
Louisville, Ky
Hi LadynKy,
Lydia
Ive sent several private messages which end up going back to my non responsive Care Specialist. You send me a message Lydia.
JeepCares
Auburn Hills, MI
JL
Hi LadynKy,
Not a problem. I have just sent you a private message. I look forward to assisting you!
Lydia
LadynKy
LadynKy
Yolanda
Louisville, Ky
It’s stock. No mods at all.
LadynKy
LadynKy
Yolanda
Louisville, Ky
No mods at all. It’s stock.
