Cwu21
- Joe
- Dec 23, 2017
- SAN Diego/ Meridian ID
- 2020 JLURD
- Build Thread
- Link
- Vehicle Showcase
- 1
I went with the 2.5” lift, and so far the look is great. I would say just about everything fit as planned. Now the metalcloak instructions call to put a rear sway bar spacer in and it drops the rear sway bar about an inch. The sway bar now has about an 1/8” gap between that and the def tank. I am not sure if that will flex and rub into the tank or not. I wonder if I should just do away with the spacer kit all together. I wonder if @Metalcloak has an answer for thatWhat size lift did you go with, how much did it set you back?, I think the next upgrade on my end is the lift, just unsure which one to go with, but since my rig is stuck at the dealer I guess I have sometime to figure out which way to go, I was originally hoping to go with something that added King coilovers, but they are expensive and I am not sure if the coildover conversion would be good (or better I may say) for off roading, I have many things to install still so I am waiting a bit before making tha final call, I am also nervous about fitment, it seems most manufacturers expect things to "fit" since it's a JL, nice to hear most fitted properly
