CV Joint Front Axle
NeilP
Neil
South Dakota
2024 Jeep Wrangler Sahara Unlimited
RETIRED!
This.
I put RCV shafts in mine. It's a lot smoother in tight turns in 4WD then with the stock u-joints. Not so jerky.
What all is involved with changing over to CV joints?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Are you sure you want to introduce a weak spot into your Jeep? They can be easily destroyed by a branch.
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Like others, to my knowledge, only Jeeps with the 4wd auto have CV joints. Please provide a picture of your transfer case shifter and/or dash cluster.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Gotta pull the unit bearings off and pull the shafts. Then reassemble.
If you have the FAD (front axle disconnect) there are a few more moving parts to deal with. And you have to choose whether to bypass that or not when you buy the parts.
rkwfxd
Rich
Whittier
Unemployed
My 21 Rubicon had CVs. I broke one on the trail. Jeep covered it under warranty. Now I am running DS Cro Mo shafts with 1410 U-joints. The originals are in my shed for spares. I figure if I keep them I will never need them.
KevinBoston
KevinBoston
Boston, ma
2024 Jeep Wrangler
Only part time 4WD
Jeep Wrangler JL CV Joint Front Axle IMG_4072
Jeep Wrangler JL CV Joint Front Axle IMG_4066
Wbino
NJ
They eliminated separate temp controls for driver/pass?
AnnDee4444
'18 JLR 2.0
BLS65
Bret
Saint Johns, Florida
, 2000 TJ, 77 CJ7, 2024 JLU Willys, 2025 Gladiator Rubicon X
Business Development Manager.
I do not have 4-wheel drive auto. I have the part-time 4WD. I noticed that my 2024 Willys has CV joints. I had not seen that on a wrangler before.
I did read that the full-time system had the CV joints.
Same here, I took delivery last week on my 24 Willys, Command track part-time 4wd and CV joints.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
A benefit of CV joints in the axle that people often overlook is they maintain full strength when turned sharp while traditional u-joints only have full strength when the wheels are pointed straight ahead.
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
Boots suck. I damaged it on the trail and Mopar doesn't sell them alone, they come with new axle assembly ☹
Protect your boot thingies from trees.
2024 Willys
Jeep Wrangler JL CV Joint Front Axle 20251019_130952
Jeep Wrangler JL CV Joint Front Axle 20251020_122634
gek
Code Monkey
Ratbert
PNW
Software Engineer
2024 Willys
My paranoia about a mere twig taking those out was a big part of me avoiding 4 auto.
