Cutoff and pattern of LED replacement in halogen housings
WXman
Central Kentucky
2018 Wrangler Unlimited
The passenger side light is made a little different I think. Mine casts light a little higher and farther right also compared to the driver side light. I think this is by design to illuminate the side of roadways where pedestrians and animals are commonly found.
jlsahara
Oscar
AZ
2018 JLU
I got impatient with the Mopar eD unit getting released so I bought some LED bulbs from Amazon “Hikari”.
I didn’t go Oracle because I was unsure on the beam pattern with any of these LED bulbs and these were only $89.
I like the adjustable beam pattern rotation “thingy”. I lined up the beams to point east to west and I haven’t had any issues at all. The cuttlefish isn’t as sharp as some OEM LED offerings but it’s not any worse than the Halogens and it’s not shooting every where, which was my fear. Most importantly, got rid of the ugly yellow color.
I don’t seem to have the right side beam aiming further and higher than the left like mentioned in the previous posts.
  • Like
Reactions: zyt
maweber
Monroe, WA
JLU Sport S
Has any one retained the usefulness of their high beam, especially cruious with those that have bulbs that rotate to you can face the diodes N-S or E-W. The Morimoto's don't have a rotating base and when I attempt to turn the high's on the results are laughable, near indistinguishable. Plus I am a getting flashed more recently because "i have my brights on".
jlsahara
Oscar
AZ
2018 JLU
The LED’s I used are adjustable and the high beams are still effective when used. Maybe I got lucky with the type of LED I used.
maweber
Monroe, WA
JLU Sport S
Did you rotate them so that the diodes were facing up-down or left-right? Might are sitting at an angle. Thanks.
jlsahara
Oscar
AZ
2018 JLU
Mine are sitting so the chips/diodes are facing left to right. That should be the proper orientation for these halogens.
Turbo_punkn
Greg
Bath, pa
2018 JL
I guess I better change my bulbs around. The diodes are facing up and down.
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
What type of LED did you use?
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
butcho
Charlotte, NC
2018 Jeep Wrangler JLU
There's a lot of awful information on the forums.
There ARE some LED replacement bulbs that have wonderful beam patterns in halogen housings. In fact, testing has showed that some of them outperform dedicated LED housings. The Supernova V.4 bulbs are a good example.
I have twice the light output now that I had when stock, and I NEVER get flashed by oncoming traffic. The beam patterns are nice and tight, the sides of the roadway are lit, and the color of the light is intense and strong. And, I'm in for about $300 total, instead of $900 or whatever the LED package costs from the factory.
Definitely would love some links to this information and especially those supernova bulbs you mentioned. Thanks!
Stingrey
Paul
Waterloo ON
2020 Jeep JTR & 2015 RR
Civil Eng.
Just Google Headlight Revolution and you'll find the Supernova V4
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Here are BEAMTECH H13’s I picked up off Amazon for $40, I have been out a few times and so far have not been flashed and if they don’t last long I’m not out a ton of $$$$
