Renegade Wrangler
- Gasan
- Oct 14, 2018
- Atlanta, GA
- Wrangler JL Rubicon
- Occupation
- Spice Man
Thank you,Same bolt. Chassis is chassis
Like this?Looks better and more long term reliable. Now get some split loom and clean and finish the look.
Is it prudent to have independent fuses on each wire in this case?If that is the case ,yes you can just hook all grounds to chassis and all power wires to one 15amp switch.
You could make a case for that but in this situation where we are only talking about 10 amps of current, I wouldn't worry. I would change the fuse in the factory box to the amp rating needed if lower than the 15amp fuse it comes with.Is it prudent to have independent fuses on each wire in this case?
Not saying it's a bad idea, but that's getting to a point that would be like putting a separate circuit breaker on every single outlet in your house. Not really necessary.Is it prudent to have independent fuses on each wire in this case?
