Cut/trim KC Hilites wiring harness when using built-in Aux switches?
baz
baz
Baz
Montreal, Canada
Rubicon Unlimited 2019
If that is the case ,yes you can just hook all grounds to chassis and all power wires to one 15amp switch.
Is it prudent to have independent fuses on each wire in this case?
Dagwood
Alabama
2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
You could make a case for that but in this situation where we are only talking about 10 amps of current, I wouldn't worry. I would change the fuse in the factory box to the amp rating needed if lower than the 15amp fuse it comes with.
  • Like
Reactions: baz
robaw
Rob
Iowa
Not saying it's a bad idea, but that's getting to a point that would be like putting a separate circuit breaker on every single outlet in your house. Not really necessary.
  • Like
Reactions: baz
Mac Haik CDJR Georgetown
