Cut/trim KC Hilites wiring harness when using built-in Aux switches?
baz
baz
Baz
Montreal, Canada
Rubicon Unlimited 2019
I'm not a smart man when it comes to electronics, I got it to work using the relay and only chopping off a little bit of the wiring, and I called it a win :)
We literally couldn't be more similar :). I went through the same steps. First time doing anything like this and felt like a miracle when it worked.
But doing it "right" couldn't be any simpler. It's actually the unnecessary harness that makes things confusing.
The instructions are literally:
1. Attach the lights' red wires to the aux wire
2. Attach the lights' black wires to the battery
That's it. I highly recommend it (no pressure lol). Here is an image of my functioning setup:
Dagwood
Alabama
2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
It's is that simple, the aux switch is already set up fused and relay. Just connect power to aux switch wire and ground to chassis. No need for the double fuse. If your concerned about not being fused correctly then just change the fuse in the factory box to whatever your need is, down not up.
And I do have many years experience in 12v professionally and currently build cars for a living.
My only advice on your pic would be to lose those wire nuts and either solder and heat shrink or get some heat shrink butt connectors, that would water proof your install. Also no need to ground to battery, in your pic lower left corner you'll see and ground bolt. In perfect placement.
S2k Chris
Arlington Heights, IL
AP1 S2000, Rubicon 4xe
Finance
Here’s mine. Don’t mind the tape, it’s soldered and shrink wrap underneath it.
  • Like
Reactions: baz
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, upgrades in progress!
@S2k Chris I like the the look of the trimed close-outs. :rock:
Gregj
Gregj
Greg
West Texas
The plastic bat wings that go between the front bumper and the flare on a Sport.
Gregj
  • Like
Reactions: baz
S2k Chris
Finance
Thanks, I put those on when I had the whole front end taken apart for the lights. Appreciate your sending the screws with them!
S2k Chris
Finance
What are "trimmed close-outs"?
When you take the Euro bumper Wong things off it leaves the back of the bumper (and the fog light hardware etc) open and exposed and it doesn’t look clean. @Gregj was nice enough to send a set that had been trimmed down to close it off to me to install.
  • Like
Reactions: baz
baz
baz
Baz
Montreal, Canada
You're working me to the bone here @Dagwood but I did as you asked:
Thank you :clap:
Dagwood
Alabama
Thank you :clap:
Looks better and more long term reliable. Now get some split loom and clean and finish the look.
Renegade Wrangler
Gasan
Atlanta, GA
Wrangler JL Rubicon
Spice Man
Aux switches 1&2 are rated 40 amps each. The relay with the KC wiring harness is 2x20 amps, so basically the same. Some could contend that there could be a scenario where one wire could pull enough power to not blow a fuse but still melt a wire (and possibly start a fire) but I seriously doubt that would ever happen. IMHO either way of wiring them is perfectly acceptable (I have plenty of education/experience in low-voltage wiring and electronics).
If possible to pick your brain, I have a set of KC flex spots drawing 2 W each total 4 W and a KC flex bar drawing 5 W and I wanted to have all on one Aux switch the 15 W not the 40. Is that doable.
Dagwood
Alabama
I think you mean that it draws 4amps of current and 5 amps. Those spots are 10 watts each.
If that is the case ,yes you can just hook all grounds to chassis and all power wires to one 15amp switch.
If you want an exact amp pull it would be by dividing the watt total by 12volts to equal amp draw.
Voltage times amperage equals wattage
Wattage = power
Amperage = current drawn
Voltage = 12 volts in this case
Renegade Wrangler
Gasan
Atlanta, GA
Wrangler JL Rubicon
Spice Man
Wattage = power
:fist bump: Thank you should I separate the grounds or can they be connected to the same bolt
Diode Dynamics
