Cut/trim KC Hilites wiring harness when using built-in Aux switches?
baz
Baz
Montreal, Canada
Rubicon Unlimited 2019
The wiring harness that comes with KC Hilites (A-pillar Apollos in my case) is massive and bulky. Since I have the built-in auxiliary switches most of it is unused. Does anyone know if it's possible to cut parts of it off for a more direct and slim install when using aux switches?
NickTinVA
Nick
Leesburg, Virginia
2019 Jeep Rubicon
Yep! That's what I did. Super easy. You don't need any of the switch assembly or wire run.
  • Like
Reactions: baz
baz
baz
Baz
Montreal, Canada
Great to hear! Would you mind sharing a pic of what you did if you get the chance? I assume you still have the relay cap piece?
baz
baz
Baz
Montreal, Canada
I did it and it was an easy job! Thanks for the boost of confidence @NickTinVA. For anyone else curious, here are the instructions:
NickTinVA
Nick
Leesburg, Virginia
2019 Jeep Rubicon
Nice job! I apologize, I missed your request for pictures, but you nailed it.
  • Like
Reactions: baz
NickTinVA
Nick
Leesburg, Virginia
2019 Jeep Rubicon
Here's mine. Since the relays are fuse protected you can cut even more away if you want to. All you need are the positive and negative leads direct from the lights after the Y splice.
  • Like
Reactions: baz
baz
baz
Baz
Montreal, Canada
Do you still have the relay cap in there?
If not how do you get the switch wire to do the switching?
robaw
Rob
Iowa
You can just wire the red wires from the lights to the aux switch wire and the black wires from the lights to ground if desired. The aux wire already has a dedicated relay and fuse so leaving the inline fuse and relay from the harness is overkill. I will admit I left the relay and fuse intact, but I know I didn't have to.
baz
baz
Baz
Montreal, Canada
It works! Excellent. I got confused a bit because when you use the harness it still requires a direct connection to the battery, so the switch portion, I don't think, is supplying power in that case, just connecting the other power wires.
I did decide to leave the fuse that's already attached to the KC wire because I'm pretty sure the amps aren't exact. Is that a good idea?
robaw
Rob
Iowa
Aux switches 1&2 are rated 40 amps each. The relay with the KC wiring harness is 2x20 amps, so basically the same. Some could contend that there could be a scenario where one wire could pull enough power to not blow a fuse but still melt a wire (and possibly start a fire) but I seriously doubt that would ever happen. IMHO either way of wiring them is perfectly acceptable (I have plenty of education/experience in low-voltage wiring and electronics).
  • Like
Reactions: baz
baz
baz
Baz
Montreal, Canada
NickTinVA
Nick
Leesburg, Virginia
2019 Jeep Rubicon
  • Like
Reactions: baz
S2k Chris
Arlington Heights, IL
AP1 S2000, Rubicon 4xe
Finance
Did this exact thing yesterday. Wired to Aux 4. chopped the black wire off after the relay, left about 8" of the green wire, spliced/soldered/shrunk wrapped to the blue/pink Aux 4 wire.
FWIW, I used the bolt holding the plastic battery thingy to hold the relay in place, it's down in the little area where the Aux wiring sits.
Now I just need the Mopar bumper brackets to be delivered and I can install the lights themselves; I just have the wiring all tucked next to the battery until the brackets come in.
S2k Chris
Finance
You don't even need the relay thing, you can chop more.
I'm not a smart man when it comes to electronics, I got it to work using the relay and only chopping off a little bit of the wiring, and I called it a win :)
Northridge4x4
