californiajeeping
- Feb 1, 2019
- California
- JLUR
Printable PDF version attached.
TEXT VERSION
Revision 2 June 2019 Customer Satisfaction Notification V41
Steering Damper
NOTE: Figure 2 position of Steering Damper Intake Bulge location updated.
Dealer Service Instructions for:
Remedy Available
2018 - 2019 (JL) Jeepď˘ Wrangler vehicles
NOTE: Some vehicles above may have been identified as not involved in this campaign and therefore have been excluded from this campaign.
IMPORTANT: Some of the involved vehicles may be in dealer new vehicle inventory. Dealers should also consider this requirement to apply to used vehicle inventory and should perform this campaign on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process.
Subject
The front suspension steering damper on about 192,000 of the above vehicles may not effectively damp oscillation of the steering system, resulting in a sustained shake or shimmy in the steering wheel. This can be more noticeable when driving at speeds exceeding 55 Miles Per Hour (MPH) 88 Kilometers Per hour (KPH) after contacting a bumpy road surface and in temperatures below 40° Fahrenheit (5° Celsius).
Repair
Replace the front suspension steering damper on all of the above involved vehicles. ďŁ Copyright 2019, FCA US LLC, All Rights Reserved (kka)
Customer Satisfaction Notification V41 â Steering Damper
Page 2
Parts Information
Part Number Description
CCUKV411AA Left Hand Drive (LHD) Part Package Each package contains the following components:
Quantity Description
1 Steering Damper, Left Hand Drive
Parts will be manually allocated to dealers based on VIN assignment. This process will continue to during the next several months.
CCUKV412AA Right Hand Drive (RHD) Part Package Each package contains the following components:
Quantity 1
Part Number
Description
Steering Damper, Right Hand Drive
Description
CCUKV413AA Fastener Part Package (LHD and RHD)
Each package contains the following components: Quantity Description
1 Bolt, Axle Mount Steering Damper
1 Nut and Washer, Axle Mount Steering Damper 1 Bolt, Bracket Steering Damper
1 Nut, Bracket Steering Damper
Parts Return
No parts return required for this campaign.
Special Tools
No special tools are required to perform this service procedure.
Customer Satisfaction Notification V41 â Steering Damper Page 3
Service Procedure
NUT AND BOLT
STEERING DAMPER
BOLT AND FLAG NUT
Figure 1 â Steering Damper
AXLE BRACKET
TIE ROD BRACKET
Customer Satisfaction Notification V41 â Steering Damper Page 4
Service Procedure [Continued]
INTAKE BULGE
Figure 2 â Intake Bulge Location
Customer Satisfaction Notification V41 â Steering Damper Page 5
Figure 3 â Tie Rod Bracket
STEERING DAMPER BOLT
SQUARE HOLE
Customer Satisfaction Notification V41 â Steering Damper Page 6
Completion Reporting and Reimbursement
Claims for vehicles that have been serviced must be submitted on the DealerCONNECT Claim Entry Screen located on the Service tab. Claims paid will be used by FCA to record Customer Satisfaction Notification service completions and provide dealer payments.
Use the following labor operation number and time allowance:
Labor Operation Number
Replace Steering Damper 02-V4-11-82
Time Allowance
0.3 hours
NOTE: See the Warranty Administration Manual, Recall Claim Processing Section, for complete claim processing instructions.
Dealer Notification
To view this notification on DealerCONNECT, select âGlobal Recall Systemâ on the Service tab, then click on the description of this notification.
Owner Notification and Service Scheduling
All involved vehicle owners known to FCA are being notified of the service requirement by mail. They are requested to schedule appointments for this service with their dealers. A generic copy of the owner letter is attached.
Customer Satisfaction Notification V41 â Steering Damper Page 7
Vehicle Lists, Global Recall System, VIP and Dealer Follow Up
All involved vehicles have been entered into the DealerCONNECT Global Recall System (GRS) and Vehicle Information Plus (VIP) for dealer inquiry as needed.
GRS provides involved dealers with an updated VIN list of their incomplete vehicles. The ownerâs name, address and phone number are listed if known. Completed vehicles are removed from GRS within several days of repair claim submission.
To use this system, click on the âServiceâ tab and then click on âGlobal Recall System.â Your dealerâs VIN list for each recall displayed can be sorted by: those vehicles that were unsold at campaign launch, those with a phone number, city, zip code, or VIN sequence.
Dealers should perform this repair on all unsold vehicles before retail delivery. Dealers should also use the VIN list to follow up with all owners to schedule appointments for this repair.
VIN lists may contain confidential, restricted owner name and address information that was obtained from the Department of Motor Vehicles of various states. Use of this information is permitted for this notification only and is strictly prohibited from all other use.
Additional Information
If you have any questions or need assistance in completing this action, please contact your Service and Parts District Manager.
Customer Service / Field Operations FCA US LLC
This notice applies to your vehicle,
V41
LOGO
CUSTOMER SATISFACTION NOTIFICATION Steering Damper
Dear [Name],
At FCA US LLC, we recognize that the success of our business depends on the satisfaction of our customers. We are constantly monitoring the quality of our products and looking for opportunities to improve our vehicles even after they are sold. Because your long-term satisfaction is important to us, we are contacting you on important improvements we would like to make to your vehicle [1]. This will be done at no charge to you.
We are recommending the following improvements be performed on certain [2018 - 2019 Model Year JeepÂŽ Wrangler] vehicles.
WHY DOES MY VEHICLE NEED REPAIRS?
The front suspension steering damper on your vehicle may not effectively damp oscillation of the steering system, resulting in a sustained shake or shimmy in the steering wheel. This can be more noticeable when driving at speeds exceeding 55 Miles Per Hour (MPH) 88 Kilometers Per hour (KPH) after contacting a bumpy road surface and in temperatures below 40° Fahrenheit (5° Celsius).
HOW DO I RESOLVE THIS CUSTOMER SATISFACTION NOTIFICATION
FCA will repair your vehicle free
TO SCHEDULE YOUR FREE REPAIR,
CALL YOUR CHRYSLER, DODGE, JEEP OR RAM DEALER TODAY
WHAT IF I ALREADY PAID TO HAVE THIS REPAIR COMPLETED?
If you have already experienced this specific condition and have paid to have it repaired, you may visit www.fcarecallreimbursement.com to submit your reimbursement request online. [2] Once we receive and verify the required documents, reimbursement will be sent to you within 60 days. If you have had previous repairs performed and/or already received reimbursement, you may still need to have the repair performed.
We apologize for any inconvenience, but are sincerely concerned about your satisfaction. Thank you for your attention to this important matter.
Customer Assistance/Field Operations FCA US LLC
[Model Year and Model]
VIN XXXXXXXXXXXXXXXXX
VEHICLE PICTURE
YOUR SCHEDULING OPTIONS
1. RECOMMENDED OPTION
Call your authorized Chrysler / Dodge / JeepÂŽ / RAM Dealership.
2.Call the FCA Recall Assistance Center at 1-800-853-1403. An agent can confirm part availability and help schedule an appointment.
3.Visit recalls.mopar.com, scan the QR code below, or download the Mopar Ownerâs Companion App.
Get access to recall notifications, locate your nearest dealer, and more through this website or Mopar Ownerâs Companion App. You will be asked to provide your Vehicle Identification Number (VIN) to protect and verify your identity.
DEALERSHIP INSTRUCTIONS
Please reference CSN V41.
of charge (parts and labor). To do this, your dealer
will replace the steering damper. The estimated repair time is half an hour. In addition, your
dealer will require your vehicle for proper check-in, preparation, and check-out during your
visit, which requires more time. Your time is important to us, so we recommend that you
schedule a service appointment to minimize your inconvenience. Please bring this letter with
you to your dealership.
QR Code
Mr. Mrs. Customer 1234 Main Street Hometown, MI 48371
[1] If you no longer own this vehicle, please help us update our records. Call the FCA Recall Assistance Center at 1-800-853-1403 to update your information.
[2] You can also mail in your original receipts and proof of payment to the following address for reimbursement consideration: FCA Customer Assistance, P.O. Box 21- 8004, Auburn Hills, MI 48321-8007, Attention: Recall Reimbursement.
TEXT VERSION
Steering Damper
Remedy Available
Subject
Repair
Page 2
Parts Information
Quantity 1
Part Number
Description
Description
Parts Return
Special Tools
Service Procedure
- Place the front wheels in a straight ahead position.
- Raise and support the vehicle.
- Remove the steering damper nut and bolt from the tie rod bracket (Figure 1).
- Remove the steering damper bolt and flag nut from the axle bracket.
NOTE: The damper flag nuts and bolts must be replaced.
- Remove the steering damper from the vehicle and discard.
NUT AND BOLT
STEERING DAMPER
BOLT AND FLAG NUT
AXLE BRACKET
TIE ROD BRACKET
- Align the NEW steering damper to the mounting bolt holes on the axle bracket and the tie rod bracket.
NOTE: Location of side Intake Bulge on the base cup must be positioned in the downward position (Figure 2).
- Install the NEW steering damper bolt through the axle bracket and start it a few threads into the NEW flag nut (Figure 1).
- Install the NEW steering damper bolt through the tie rod bracket and start it a few threads into the NEW nut (Figure 3).
NOTE: Steering Damper Bolt has a square guide that must align with the tie rod bracket square hole and be fully seated (Figure 3).
INTAKE BULGE
SQUARE HOLE
- Tighten the NEW steering damper nut on the axle bracket to 80 N¡m (59 ft. lbs.) (Figure 1).
- Tighten the NEW steering damper nut on the tie rod bracket to 70 N¡m (51 ft. lbs.) (Figure 3).
- Lower the vehicle and return it to the customer.
Time Allowance
0.3 hours
Dealer Notification
V41
LOGO
Dear [Name],
VEHICLE PICTURE
QR Code
