Never3nuff
- Chad
- Feb 2, 2018
- Fort Worth TX
- '18 JLUR , '18 Jaguar F-Pace S
- Occupation
- retired
Looks great! I love my Mopar lift and think you will as well. Mopar and Rock Krawler are both coming out with new perches that will essentially eliminate the bow that you might get.I installed a RC 2.5” spacer lift last week and even though it looked much better, I wasn’t satisfied. I wanted to run the spacer lift until more lift options became available (Teraflex, Rubicon Express, JKS). I found a local dealer in Dallas that had two Mopar 2” lifts in stock. I used the 15% off Jeep Accessories Coupon so I ended up paying $1295. Hopefully I won’t have the spring bow issue. I installed most of it last night. I didn’t measure before and after but it looks like it’s almost an inch taller than the spacer lift. I still need to torque all the bolts down and go for a test drive. Pic is before with the spacer lift.
Is the RC2.5 lift all around spacers or just front. Did you like the lift?I installed a RC 2.5” spacer lift last week and even though it looked much better, I wasn’t satisfied. I wanted to run the spacer lift until more lift options became available (Teraflex, Rubicon Express, JKS). I found a local dealer in Dallas that had two Mopar 2” lifts in stock. I used the 15% off Jeep Accessories Coupon so I ended up paying $1295. Hopefully I won’t have the spring bow issue. I installed most of it last night. I didn’t measure before and after but it looks like it’s almost an inch taller than the spacer lift. I still need to torque all the bolts down and go for a test drive. Pic is before with the spacer lift.
I’ve been holding off buying the lift because of the bowing. Can you show us the springs?I noticed the spring is a little close to the upper bump stop but I don’t see any spring bow. Good to hear about the new perches.
