cooltech tow harness causing dead battery
Sprint7
Louisiana
2004 LJ 2018 JL
Myself and a friend installed the cooltech tow harness on both our our jeeps (2018 & 2020). After towing an entire day both of the jeeps would not start with a dead battery. Next day, same thing. Finished the trip by removing the battery cables.
Any suggestion on what we did wrong? Followed this video for the install.
DirtRoad
Las Vegas
2018 JLU
Do you have a braking system installed that uses the Jeep battery? If so, you might also want to install a charger that's powered by the 12v wire from your tow vehicle. That should keep the battery charged.
If the CoolTech harness is installed correctly, I can't see why it would be killing the battery.
Sprint7
Sprint7
Louisiana
2004 LJ 2018 JL
Neither of us have a breaking system on the jeeps.
I can't see how the cooltech would effect the battery but that is the only thing that was added.
Sprint7
Sprint7
Louisiana
2004 LJ 2018 JL
@CoolTech any suggestions on possible causes or where I screwed up the install??
Jmonroe
Jay
2020 JLUR and a '99 Camaro SS convertible I bought new
It can't be the Cooltech, properly installed. It doesn't use power, just reroutes the source. Maybe something in your set up procedure?
Your situation is not uncommon, not just in Jeeps. For piece of mind I installed the RVI toad charger. About $80 and 10-15 minutes to install. That will eliminate that issue regardless of the source.
cmcclintock
2018 Rubicon JL
I have a 2018 JLUR and was one of the first people to install the cooltec harness in 2018. I have never had any issues until my recent trip.
-Towed for 7 hours on the way there and Jeep battery dead…jumped it and drove it all week on the trip.
-Towed for 7 hours on the way home and Jeep battery dead when we got home…jumped it and drove it for days and had the main battery checked out and it passed as a good strong battery.
I have no idea what is could be. Could it be that lame auxiliary battery.
Sprint7
Sprint7
Louisiana
2004 LJ 2018 JL
I had this issue a few times to the point where I do not trust it. There were some other threads a while back where Cooltech was aware and trying to get a solution but not sure of the outcome. Maybe @CoolTech will chime in with an update.
Nutmeg
Connecticut
2019 Wrangler
There is a thread where led tail lights are causing this issue. Seems they use a return wire that keeps the electronics from going into sleep mode.
Sprint7
Sprint7
Louisiana
2004 LJ 2018 JL
Did they ever come up with a solution?
cmcclintock
2018 Rubicon JL
What fuse /where should I check. All off a sudden I have no turn signals on tow jeep when plugged into the RV. Jeep turn signals work fine not plugged to RV and RV turn signals work fine. Connections are good. Has to be fuse.
tae73
Ted
Missouri
2020 JLU Rubicon and 2012 JK Rubicon
Add me to the list of dead battery with the cooltech wiring system and LED lights.
cmcclintock
2018 Rubicon JL
update: my issue was just a bad fuse in the RV(I blew/user error on something else) . This cooltec harness has been going strong since 2018… never an issue.
cmcclintock
2018 Rubicon JL
How old are your batteries in the JL (both the big and small batteries)
Also , Cooltec customer service is top notch.. Consider contacting them if needed.
tae73
Ted
Missouri
2 years and they are both series 25 batteries, using the Genesis dual battery setup.
