Cooltech flat tow install -fast blinker
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
@CoolTech I am installing on my 2020 JLUR with factory LED.
I have identified all 4 wires, and made my first cut on the green. The rear signal stopped working with the cut, so I proceeded with the connection.
The longer green is connected to the front portion of the cut wire and the folded piece is connected to the shorter.
The switch is in jeep mode.
I tested the right turn again, and the lights all work, but the dash flasher is much faster now. The left turn is normal pace, as I have not cut that wire.
I do not want to cut the remaining wires until I know this kit works with factory led.
Can you please confirm this should work with LED and if so, what if anything, I should do in regards to fast blink.
Redbaron73
Redbaron73
Ronnie
Odd thing, I went to take a video of the speed and it is now normal.
I am assuming the speed increase was due to my testing it with the wire missing and it took some time to recognize the light was back in place.
Jmonroe
Jay
2020 JLUR and a '99 Camaro SS convertible I bought new
I just finished the Cooltech install, everything works fine. It may simply have been the "computer" took a minute to recognize to restored connection. The installation video I watched mentioned it might.
PyrateCex
Abbey
Lancaster, CA
2018 Jeep Wrangler Sport Unlimited JLU
Engineer
I did my install over a year ago and had no issues. Well, other than someone flipped the switch one time. I also have the LED tail lights.
BobP55
Robert
New Hampshire
2020 JLU
I just installed the Cool Tech harness in my 2020 JLU Sahara, hooked up to coach and light all work except only one side parking light. Amy thoughts?
patternman
George
Phoenix AZ
2019 JLUS, 2014 & 2001 Indian
I used a safety cover to stop accidental position change. When the cover is up it can be placed in RV mode & simply flipping the cover closed flips switch to Jeep mode. Yes I know the labels aren't parallel, don't care it's functional.
Jeep Wrangler JL Cooltech flat tow install -fast blinker IMG_20200823_142501
Jeep Wrangler JL Cooltech flat tow install -fast blinker IMG_20200823_142455
