Redbaron73
@CoolTech I am installing on my 2020 JLUR with factory LED.
I have identified all 4 wires, and made my first cut on the green. The rear signal stopped working with the cut, so I proceeded with the connection.
The longer green is connected to the front portion of the cut wire and the folded piece is connected to the shorter.
The switch is in jeep mode.
I tested the right turn again, and the lights all work, but the dash flasher is much faster now. The left turn is normal pace, as I have not cut that wire.
I do not want to cut the remaining wires until I know this kit works with factory led.
Can you please confirm this should work with LED and if so, what if anything, I should do in regards to fast blink.
