Cool Tech's CB Antenna Kit for JL Wrangler - Available Now
jeepnjam
Jameson
Chattanooga, TN
2021 Sarge Green Rubicon 392
The longer bolts you will supply, will it be a grade as strong as the Mopar kit. I ask because that bracket is under a lot of stress from my 37 tires. How is this shipped, I'm in Fl.
I am about to install one of these on my Jeep Rubicon. I'm going to run a spring with my antenna. Is it recommended to install the bracket on the top door hinge over the bottom door hinge? I'm worried the antenna will hit in my parking garage if I mount the bracket on the top hinge, was thinking of putting it on the bottom one.
Thank you - Great product!
CoolTech
Rock Sponsor (Level 1)
Kendall
Santa Clarita, CA
2018 Rubicon
Generally speaking, the higher the antenna, the better the reception.... but then there's the practical side!! Choose the height (hinge( that will work best for you!
Andy2434
Andy
Las Vegas/San Francisco
'19 Billet JLUR, ‘20 Mustang GT/Prem/6MT/PP1
Retired/Leisure
LOL . . . Ordered my CB antenna kit from CoolTech a few moments ago. Now, I find this thread.
Looking forward to receiving it and setting it up.
jeepnjam
Jameson
Chattanooga, TN
I am having trouble tuning my antenna from the cool tech kit.
Channel one SWR reading is 1.1; channel 40 reading is 2.5. I have adjusted the antenna at the top to the shortest possible length - so what do I do now?
I was tuning in a wide open parking lot at a high school. It’s on top of a hill with no power lines within 100 ft of my Jeep. Top was up, all doors closed and Windows rolled up.
Any help would be appreciated.
Thank you!
Andy2434
Andy
Retired/Leisure
Installed my CoolTech kit with a Motorola 75-822. The install was a breeze. I opted to use a quick disconnect. The said allowed me to mount the 4' Firestik on the top hinge assembly and easily remove it for situations that may require its removal.
Have it all tuned and working really well. SWR of 1.4 on channels 1 and 40.
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
2018 JLU Rubicon, 2014 JK Willys, 1999 TJ Sport, 1966 CJ5-A
Thank you!
I have a video on tuning it if you haven't seen it already. I would double check all of the following..
- Double check all connections, make sure they are tight
- Make sure you dont have any coils of coax if you have extra cable, run it somewhere to avoid coils
- Make sure you have a good ground
- When you tune it, make sure you have the rubber tip back on, plus the lock ring tight on the adjustable part.
- Make sure all doors, tops, windows are closed, no one outside.
- 10-15 meters Away from all buildings, cars, power lines, trees, be in the middle of no where.
Niteshooter
Kevin
Toronto Canada
86 Jeep CJ7, 86 T-Bird Turbo Coupe, 00 Saturn, 10 smart, 11 JK
Thank you!
Antenna mounting on Wranglers is a challenge..... I read from the very beginning of this thread because I was curious. Mounting dead centre on the hood would be the 'best' spot but aesthetically not so nice. Dead centre on the roof of the HT would be good if it was metal and for cars with fiberglass bodies one solution was to install a ground plane kit which was basically along the line of adhesive backed foil. But on a soft top that option isn't possible.... Actually antenna mounting on most new vehicles is a real challenge especially if you don't want to start drilling holes in the body....
Rule of thumb with 2 way radios, mount on the highest part of the vehicle as close to the centre as possible. This all has to do with how the antenna radiates it's signal so mounting for instance on a corner tends to skew the signal slightly towards the opposite corner. Typically though say for use on the highway you go back passenger corner and that tends to direct the signal towards the front drivers corner which is good for hitting oncoming traffic. This link might help,
http://www.rfcafe.com/references/po...acement-popular-electronics-november-1966.htm
Your SWR issues may have something to do with how low your antenna is vs using the upper location, I understand why you did this but having the antenna sitting across from all that metal isn't the greatest. Also technically you want to get as much antenna as high as possible to optimize performance. Might be better to put the antenna on a quick disconnect and use the upper hinge bracket. Downside is this makes the antenna exceptionally easy to steal. I just wind up unscrewing the one on my CJ when I have to park it in the garage. Mount is attached to the metal bump stop bolted to the body tub which is a decent location since it places the antenna away from the tire.
I just bought a used JK and had a buddies shop make me a bracket which mounts to the top tailgate hinge. Not possible on your JL though due to the changes to the design of your hinges. But it was able to get the antenna away from the tire which is where many JL owners mount their antennas on the bracket for the spare. Not an ideal location because it's sandwiched between the tire and rest of Jeep.
As far as getting a decent SWR, way back when I first got into radio in the late 60's you could buy antenna tuners, amateurs called them trans matches and CB'ers just called them antenna matchers or something like that. They brought the SWR down but are not ideal in that they are in a sense tricking the setup into 'thinking' the SWR is good. Only bring this up in case someone suggests one.
When you say you've adjusted the antenna, I'm guessing it's a top loaded fibreglass whip? (eg there is a coil of copper wire at the top of the antenna). So to tune those styles of antenna you have to pop the cap and start cutting off the coil. Based on where you have the antenna, I personally wouldn't have done that since once that wire is cut you can't get it back. There are also antennas that you can tune by moving a short metal rod at the top of the antenna by loosening a set screw. If you have one of those and you've backed the rod down as far as possible it may need to be cut. Again though I personally would not do that especially if you decide to move the mount up to the top bracket.
Had a bracket fabricated at a friends shop for my JK, unfortunately the JL doesn't have the exposed bolt to be able to tap into.
I've used the Cobra WX radio in my car for about 10 years, only thing I had a problem with was the volume control. It started to get crackly and eventually would cut out completely. A shot of Dioxit fixed the crackle but I eventually had to take the handset apart and re-soldier the wires as one had come loose. Otherwise not a bad little radio when you don't have a spot to put an actual transceiver. Midland also makes a hand held that comes with an in car mounting kit which is pretty handy. I also own one of these and it works well for what it is. It is a bit disconcerting to see an open TNC connection on the top of the radio when the antenna is removed though. FYI the rubber duckie antenna is disconnected electrically when the radio is attached to it's in car base. I just put a short ham antenna in the hole to make it look better. Otherwise you could just leave the stock antenna on the unit but then it gets kind of unwieldy in your vehicle.
TreeHugger
Jim
Austin, TX
TBD
@CoolTech do you have plans for a GMRS antenna mount? I'm looking at getting the Midland MXT275 but don't see much in the way of JL antenna mount options for that GMRS radio.
Dogboyslim
Wisconsin
2018 JLU Rubicon Punkn.
Question: Does anyone know the size of the grommet in the tailgate or where to source a spare? I'm notoriously bad with these things, and want to buy a spare or 2 before I begin running the wire.
Referencing the oblong grommet above the one this person used to route the wire.
prerunner1982
Jon
Oklahoma
XJ Cherokees
You need an NMO antenna mount, very common in the ham radio world. @Hgrace did a nice job with a simple L mount under the cowl.
psuntlion
Jason
Devore, CA
2018 JLUR, Camaro ZL1 1LE, BMW M3, R1250GSA
Just ordered the All-in-One Cobra kit after reading this entire thread. I'm really impressed with Cool Tech's responsiveness and detailed answers to everyone's questions. I opted for the 4' antenna with a quick disconnect so I can just store the antenna inside the Jeep when I'm not using it.
I had actually already ordered a Cobra 19 because that's what I had in my last rig, but the 75 looks like it will be much better to mount. Looking forward to getting it installed!
DeekT
Deek
Illinois
2018 Punk'n JLU Rubicon (mine), 2018 White JLU Moab (wife)
One suggestion, I also purchased a 3' antenna along with the 4' antenna both with quick disconnects. I run the 3' daily so I can clear most everything especially parking garages. I keep the 4' strapped between the top and the sport bar and I switch to that for road trips or whenever I need to get more distance.
SSVi
Damon
Idaho Falls
2021 392XR
Extreme metal drummer/ large cat wrangler / gun modder
Has anyone wired up their Cobra to one of the aux switches for power? How tough was it to do if so?
millerjl
Chuck
San Diego, CA
JLU Rubicon
It’s easy, the wires are right up under the glove box which is where you can hide the module anyways.
