control arm to frame mount damage ?
Jarg1
San Jose, CA
2021 JLUR, 1997 911 (aka 993), 2023 Telsa 3
Jeep modder, among other things.
Yes those are weld on skids for the front axle bracket. I had them on my JK. I am currently running the Hard Rock skids for the front and rear axle. Heavy duty and bolts on to existing brackets.
Yes, I also have the Rock Hard front and rear LCA skids, plus Rusty's rear frame side LCA skids. What I can't find is a front frame side LCA skid.
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
Sorry. I should get my reading glasses. Frame mount skid. Got it. :facepalm:
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
Has anyone found a front frame side lower control arm skid yet?
I have hit my driver’s side pretty good a few times and would like to protect it before it gets worse.
Funny enough, I have yet to even scrape the front axle side LCA mounts and have barely kissed (once) the rear frame side LCA mounts and that seems to be where most others make contact. Rear axle side and shock mounts are another story, but everyone makes those skids.
You can see the initial dent in this pic at Hidden Falls, but I made it worse in Rubicon Ridge, and my girlfriend helped to add to it on the steps at Marblehead.?
Jeep Wrangler JL control arm to frame mount damage ? 1656723736349
sherpaJL
Keystone State
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
bump
This is what you're looking for
Jeep Wrangler JL control arm to frame mount damage ? bounce_zps82db53fe
https://www.rockhard4x4.com/product_p/rh-80516.htm
ROCK HARD 4X4™ BOLT-ON FRONT UPPER/FRAME SIDE CONTROL ARM SKID PLATES FOR JEEP JL AND JT 2018 - CURRENT [RH-80516]
Jeep Wrangler JL control arm to frame mount damage ? RH-80516-2T
Jeep Wrangler JL control arm to frame mount damage ? RH-80516-3T
Philly_
2022 JL Rubicon
jhackathorne
Denver
'21 JLUR
This is a good find. Mine are pretty tore up. I can’t believe there aren’t other manufacturers making this as well.
limeade
Guy
Reno, NV
I have Metalcloak weld-on front LCA and Artec bolt on rear LCA skids.
If you’re going to be playing in the big rocks, I highly recommend LCA skids. Both front and rear skids have taken some hits and I was glad to have the protection versus suffering mount damage. The rear Artec skids are very beefy and well made. I highly recommend them.
I had a local shop weld the fronts on for $30 total.
jhackathorne
Denver
'21 JLUR
These aren’t the same as what you’re talking about. These are the frame side, not axle side.
limeade
Guy
Reno, NV
My bad, I misread what the OP was looking for.
In that case, I've never experienced or seen a need for frame side CA skids. The proper rock sliders usually will catch on the rock and keep the frame CA mounts from being damaged.
sherpaJL
Keystone State
I have these bolt-on skids
Rock Hard front lower arm, axle side
Rock Hard front lower arm, frame side
Artec rear lower arm, axle side
Rusty's rear lower arm, frame side
jhackathorne
Denver
'21 JLUR
Not the case for me. Sliders are higher up than the CA mounts on the frame side. They’re all bent and scratched up. The frame side mounts, not sliders I mean.
BDinTX
Dallas, Tx
You wouldn't happen to recall what size bolts you got for the rear LCA skids would you? I'm probably going to have to order something, local stores have bad selection on hand.
limeade
Guy
Reno, NV
They use the existing shock and LCA bolt, so no need to source any new bolts.
BDinTX
Dallas, Tx
That’s what @Artec told me via email too so I put them on. I’m not 100% comfortable with the amount of thread past the bolt though. This is the LCA to axle, the shock bolt looks the same way
Jeep Wrangler JL control arm to frame mount damage ? IMG_0993
