Confirmed: Offset and backspace of stock JL Rubicon wheel
TroyBoy
TroyBoy
Troy
Vancouver Island, Canada
I thought it would stick out more than that on a -18. Considering that's a negative 44 doesn't stick out that bad but like you said that's why they make so many different wheels.you could spend weeks and weeks looking at wheels its crazy
I’ve never heard of a -44 offset before. That’s like 88mm further out than stock. That’s 3.5” further out. :surprised:
Jammer
Ft worth
Bright white JL Rubicon
I have not either black rhino makes a -44 you can talk to maximum altitude in San Antonio that's the shop that did the lift on that JL
Ape
Powell, Ohio
2020 JLU Rubi
Would you guys feel comfortable running a 17x8.5" wheel with an offset of +10mm and 5.2" backspacing?
Amescop
Alex
New York
2018 Wrangler
Guys help me out here. I’m new to this. I bought 33x12.50R20 Firestone tires and
20x10 (-18 offset) Fuel Triton D581 wheels—I love the way it looks...
Nothing rubs, what I am concerned about is the -18 OFFSET. Is this good or bad compared to the stock set up?
Would the -18 offset do any damage to the Jeep’s suspension, would it affect it?
Thank You Gents!!
TroyBoy
TroyBoy
Troy
It’s perfectly fine. They stick out farther than they need to but that sounds like the look you are after.
Amescop
Alex
New York
2018 Wrangler
Awesome!! Thank You brother.
Yes, definitely the look I was looking for.
mtomac
Michigan
2018 Wrangler Unlimited JL - 2017 Silverado 3500 Duramax - 17 Chevy Equinox
I would like to know as well. What size tire are you looking at?
WXman
Central Kentucky
Yes that would be great. +18 to +25 range is perfect, but +10 is so close that it'll look great.
This spec will put just a small amount of tire outside the fender flares.
  • Like
Reactions: Ape
Jeeper
Acura MDX 2015, Ford F150, Honda Odyssey,
This is all very confusing to me. I like a set of wheels with the following specs, 17x9.5 with a -18 offset and 4.5 back spacing. How do I compare that to the stock rubicon wheel? How far will that stick out?
I hear alot about the -12 offset being more appropriate for the JL but I don't understand what that means.
WXman
Central Kentucky
The stock JL wheel (regardless of trim level) is 44.45mm offset and 6.1" backspace.
So, in your example of a wheel with 4.5" backspace and 9.5" width that will basically be 1.5" farther outside the hub, plus the 2" of added width for a total of 3.5" farther outside the hub. It's going to stick WAY out and look like a skateboard. Not to mention it'll be hell on ball joints, wheel bearings, axle shaft ends, etc.
That's why most guys are running the 8.5" width and positive offsets because they work better with 11.50 and 12.50 width tires, and they maintain most of the tread under the protection of the fenders to prevent paint damage.
ocrejects
Orange County, CA
2021 Rubicon, 2018 JLU Rubicon, 2018 Tiguan SE
What do you mean by a positive offset can you give me example please.
TxJeepers
2022 JLUR XR
What this guy said. I know some like them to stick out, but I prefer to keep as tight in as the tires/suspension/body will allow.
millerjl
Chuck
San Diego, CA
JLU Rubicon
I had procomp rockwells on my last JK and wanted to go same route on my JL.
They are 0 offset and 4.75 back space.
I believe I can just swap these out and keep my stock KO2’s and not really have much impact correct?
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
I am running Method MR312’s with a -12 offset and 4.5 BS with 315 KO2’s wrapped around them, I was at first concerned they would stick out to far but they don’t for me, some want them even or even under the fenders but I was going for a semi aggressive look
Jeeper
I just want to say thank you very much for this explanation. These forums are amazing. I totally understand the relationship between the three different specs now.
